hole in exhaust pipe
Old Jul 28, 2011 | 05:33 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Hey. just wondering if a hole in the pipe right before the cat could cause any real problems for me. I don't know for sure, but I'd guess that it would be a fairly expensive repair, and I don't know if it is something I can leave alone for now without any problems in the near future. any thoughts are appreciated.
Old Jul 28, 2011 | 06:44 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: hole in exhaust pipe
it is something that requires attention . exhaust fumes inside a closed car can kill you . at the least smell bad and give you a headache . any auto parts store would have a temp. repair kit . a ghetto fix would be an old tin can & a couple of screw clamps . bottom line it does require attention soon . good luck .
Old Jul 28, 2011 | 07:17 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Old Jul 29, 2011 | 11:01 AM
fervernt's Avatar
alright thanks. I'll for sure get it fixed by the winter. for now, I'm not too worried bout it, because I always have my windows down. Just another cost to add to my list >_< . Any other car, I would never put up with all this lol.
Old Jul 29, 2011 | 11:36 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
That's really funny, I've got a leak in the same exact place. It has made me think about just removing the cat alltogether. The leak has been there since about April and has recently gotten louder. Definatley sounds like crap tho
Old Jul 29, 2011 | 12:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
soup can split down the side, and 3 hose clamps, quick fix as it rather flow out the pipe right.
Old Jul 31, 2011 | 05:52 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
The soup-can-fix or a patch kit would get you by for another few months.
After that, if it´s not too close to the cat, and provides some space to work with, you could have someone weld a piece of sheet over it. Just pick up a small bit of 2 1/2" exhaust pipe, cut about the patch you´ll need out of it and have the exhaust patched. The stock Y pipe is 2 1/4 so the 2 1/2" pipe should provide a perfect fit for a piece to patch with.
If you do however have some pocket money to spend, pick up a set of headers and a Y pipe, swap the cat in the process and enjoy the upgrade.
Old Jul 31, 2011 | 06:12 PM
Car: 89 GTA
Engine: 5.7 TPI L98
We'll have to see. I'm thinking of upgrading to a 3" Y-Pipe anyways. This is a perfect excuse to do so.
Old Jul 31, 2011 | 06:26 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
There is some stuff that i used a while back that actually worked called Thermosteel. I was surprised. Best to let it dry overnight tho
Dyno Don
Jan 24, 2016 08:24 AM
86CamaroDan
Sep 29, 2015 10:08 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
downsouthboy
Aug 29, 2015 11:29 AM
