Trouble connecting y pipe to headers
Old Aug 21, 2011 | 12:03 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
It's those edelbrock TES kind. I have 2 donut shaped gaskets in the ypipe and I'm trying to bolt it to the headers but I can't get em' to fit together. Am I supposed to put the gaskets on the headers and then connect the y pipe or something?
and also does anyone happen to know if I can fit the EFE valve onto the header?
Old Aug 21, 2011 | 05:28 PM
0pyders's Avatar
Re: Trouble connecting y pipe to headers
I have the gaskets in the y pipe, is this right? then just install it? When I tried it seemed like I had to make sure the gasket was getting pressed in evenly with the header or else when I tightened it it would just get lopsided and not go in anymore.
Old Aug 21, 2011 | 08:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
yeah they go into the ypipe. You did take out the old donuts out of the ypipe right? Is that ypipe made for the headers? It's not a stock ypipe is it?
Old Aug 21, 2011 | 10:42 PM
0pyders's Avatar
yes.
yes.
no, it matches the headers.
I think I just need to wrestle with it more, I'll have at it tomorrow. Thanks for the reply.
Old Aug 21, 2011 | 11:40 PM
ninetyone's Avatar
Axle/Gears: 3:42
you know the bolts go into the headers from the bottom, no nuts required.
Old Aug 22, 2011 | 04:47 PM
0pyders's Avatar
yup I put the bolts in from the bottom. I think I have it now but one question is for the y pipe gaskets, is there suppose to be any of the gasket showing after it's tightened? The gasket is sandwiched between the 2 pipes. Is that right or am I supposed to keep tightening?
Old Aug 22, 2011 | 09:39 PM
ninetyone's Avatar
Axle/Gears: 3:42
supposed to show
Old Aug 22, 2011 | 10:46 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
NO EFE
EDELBROCK TES...... good luck...... i have the same setup,the donuts fit like ****,i had a welding shop cut the flanges off and weld the Y pipe right to the headers.
I HATE EXHAUST LEAKS.
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
TheExaminer
Aug 26, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
mustangman65_79
Aug 7, 2015 09:55 PM
