3rd Gen Stainless Headers on eBay
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
Anyone used these:
http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWAX%3AIT
I came across these on eBay and was wondering about quality? No EGR? Collectors crossover to CAT?
Bruce
Bruce
Car: 1989 iroc camaro
Engine: 5.7
Transmission: the auto 700r4
Re: 3rd Gen Stainless Headers on eBay
I just put these on my motor im putting in mine...havent put them in use tho,but I can say there built way better that those $100-130 ones you see on summit and jegs!
i can get you a comparison pic of the difference (i also have those cheapies from summit/jegs)?
Engine: 305 TPI LB9
How are you connecting the collectors up? Looks like these go straight down. You doing dual exhaust? You using a CATALYTIC converter?
Are the ends of the collectors 2.5" OD?
Engine: 5.7
I got the dynomax catback system im going to throw on mine...the system is all 2 1/2 duel out muffler....from my headers I know of a shop that can custom fab a y pipe from the stainless headers to the catback...(gettig rid of the cat and running pipe)
-im pretty sure the collectors are 2 1/2 also
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
they look like a decent set of shorties. the description shows a collector outlet of 2.5 inch, with 1.75" primaries. youll probably have to have a custom ypipe made to fit them though
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
does anybody have any installed pictures of this header? I have a 7qt moroso oil pan so it took a fair deal of angles to get a proper y-pipe made up to go trought the stock routing (and rattles now)if these headers go straight down on the driver side I could make up something that would flow a lot better than what I have right now.
Engine: 305 TPI LB9
Petey,
Did you try the factory O2 sensor? I was reviewing the feedback on this eBay seller and noticed a couple of non-positive comments about some headers that the O2 sensor bungs not being the right size. These were not for these headers, but was just wondering if there was any issue there.
I also looked a little closer at the pictures of these. What quality are the mounting backers to the heads? Looks like the head sensors might have an issue as it looks like the backer plates do not have the cut outs for sensors like the water temp?
Bruce
Bruce
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Also watching this thread to see the verdict on these headers.
Transmission: T700
Hard to tell. The specifications, price and photos all look great.
Just need to hear from someone actually using them.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Did you measure these and verify the primary and collector diameters? They look identical to these, though the collector diameters are different...
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_1996wt_689
Engine: 305 TPI LB9
But they do look the same as the ad I first saw.
I have just decided to stay with stock exhaust manifolds, MagnaFlow 16450 3" Y-Pipe, 3" CAT, and 3" Hooker CAT Back system. Only thing I changed were the exhaust tips, bought some nice standard chrome single pipe tips at the swap meet last month. Those dual tips ones they send with the system are goofy looking!
Bruce
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
We eventually learn, often the hard way, that there are no good cheap headers. Any set of headers that are worth the effort to install will cost atleast $400. The headers I am currently running are still available from Summit For about $500. They are from SLP and made from 406 stainless, 16 gauge tubing with 3/8" flanges. Also important is that they have three seperate flanges on each header with no bar running between. this is why the gaskets that I installed with them 12 years ago are still there today with no leaks. They of course come with the goofy looking AIR tubes welded in. My freinds at the local welding shop took care of that for me.
Engine: 305 TPI LB9
No, not on the headers. The exhaust tips that were included with the Hooker CAT Back system! :-)
Car: 91 Camaro
Engine: 383
Transmission: th-350
Willing to pull the trigger on these and be the guiny (spelling) pig but before I do is there ANYONE else that may have these installed??? I know petey said he did but never heard back about the fitment.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Been looking at these as well, but am scared like the rest of us.
FWIW hawks has a used pair of unkonw hearders on ebay right now they took off a car, the pass has that funny 5 primary tube that snakes over the 7th as well.
Engine: LB9, LB9
I think these are made by Pro Comp Electronics.
http://www.procompelectronics.com/
The format for their part numbers matches that of the ones from the link I posted earlier. However I can't find them on their site. I emailed them to find out if they used to produce these.
I would pick these up... If the primaries are really 1.75"
Transmission: T700
It's "Guinea Pig", which is a cute little rodent, not a pig at all:
http://en.wikipedia.org/wiki/Guinea_pig
The price for stainless steel heads is great. Would be better it we could hear back from someone who has actually used them.
Transmission: T700
The Part Number is PP-HDS-FP82. I don't think they are ProComp. Instead they are probably some "white label" brand from Taiwan.
The features and price are very good though.
Engine: LB9, LB9
The eBay seller for these avoided my questions and just told me that the were made in China when I asked who the manufacturer was.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
If the fitment is crap then they're not worth the headache.. What if the leak? O2 sensors don't fit? What if it comes into contact with other things? Although 131$ plus shipping is a small price to pay for what could be an insanely great deal.. It's a tough call.. lol
Engine: LB9, LB9
Also I did some searching with the part number HDS-FP82 and came up with some results stating that they are 1.5" primaries and 2 3/8" collectors.
Car: 1971 Camaro
Engine: 427
Transmission: T700
Guess it depends whether your measure inner or outer diameter. I like these, especially for the stainless steel.
Seems they are some Chinese brand sold thru a few different people on eBay.
Just need someone to buy a set and give us the real deal.
Transmission: T700
Seems liek there are a couple of different people selling cheap stainless steel headers:
http://www.ebay.com/itm/ws/eBayISAPI...ht_1565wt_1042
$199, P/N pc5011 for Procomp brand - these look like copies of the Hooker 5022 headers.
and:
http://www.ebay.com/itm/ws/eBayISAPI...ht_4305wt_1042
$135, P/N PP-HDS-FP82 (HDS-FP82) for a generic brand.
and:
Engine: LB9, LB9
Those may have different part numbers but I'm 99% sure those are both the exact same. Just look at the flange design and how the #6 primary sweeps up and over the #8. Something I've only seen on Flowtech's, which leads me to believe that they are flowtech copies, which is why I'm hard pressed to believe they actually have 1.75" primaries.
They do look awesome I must say... Especially that 199$ one. These are long tubes, right?
Car: 1971 Camaro
Engine: 427
They advertise as long tubes on the site but i agree they look like shorty headers.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
they aren't smog legal since they have no air tubes so i can't use them.
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
Ok guys i bought a set when thay get here i will evaluate them for ya.
My car is pretty much stock anyways and thay cant flow much worse than
stock manifolds.
I will have to weld the air tubes in for inspection.
stock manifolds.
Transmission: T700
@Slow88lb9 thanks for the update. Which ones did you end up buying?
Will be interesting to see your opinion.
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
I think thay are all the same stuff just differnt sellers.
Car: 1971 Camaro
Engine: 427
That collector design is pretty terrible as well. The might give you some power over stock, but not enough to make the price and time involved with installing them worth it, imo.
You are going to have to fab or pay someone to fab a y pipe for them as well.
It would probably end up being cheaper to buy some headman shorties and matching y pipe to start.
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Engine: 305 TPI LB9
Keep us updated. I am still interested in these even though they do not have the EGR tubes.
I tried to stay stock with the Magnaflow 16450 3" Y-Pipe but the one I got does not fit, so now I am leaning towards these headers. Really did not want to change out the stock manifolds. I am interested in seeing how you fabricate a Y-Pipe to go over to the CAT?
Let me know about what you have to fabricate/cut/change regarding mounting of brackets on the front, probably nor much with the serpentine belt setup/brackets. Pre-Serpentine setup used to be a pain to put headers on as the P/S, A/C, etc always needed some fabrication of spacers or brackets to make them work.
Bruce
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Ya i recieved them yesterday and as of this moment stay away.
I bolted them up and first thing i seen was #5 spark plug is directly behind behind the tube and no way could you get a plug wire on it. I am going to see if shorty plugs will remedy the problem if it does i wiil get my calipers out and do some measuring this weekend for you guys.
The thing that sucks is thay look very good quality but that mean's nothing if thay wont work.
Engine: LB9, LB9
The biggest question is still going to remain unanswered "are they really 1.75" primaries?" because you got the ones listed as 1.5" primaries.
But seriously, couldn't you grind away part of the tube to fit the plug wire?
Transmission: T700
I think all camaro headers need short plugs.
What's the fit and finish like?
Car: 1971 Camaro
Engine: 427
My hedman shorties did not reguire short plugs.
From his review sounds like finish is nice and fit is not.
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
With the spark plug in and the header on you would not be able to turn it out a 1\2 turn and it would hit.
I picked up some shorty plugs today and i will get pics this weekend,As for fitting in the car i wont know till i put the motor in that could be a couple weeks i will keep you updated.
Engine: 305 TPI LB9
I guess it looks like these are a BUST!
Like it has been said many times, you get what you pay for! Too bad, they looked good in the auction.
