Hooker 2055 on a car with no AIR?
Car: 1985 Camaro Z28
Engine: 305 LG4
Axle/Gears: 3.08
First of all, as far as I know, the Hooker 2055 headers are only available with the AIR connections, is that correct?
My LG4 does not have the AIR system on it, as it was (and still is) not required under Alberta law. If the 2055's come with the connection, what should I do with them? I think that cutting off and welding over it would be the best, and I saw that idea when I searched. I will fall back on that if there are no other options, but I would have to get someone else to do that, which costs money, which I do not have much of.
So, my ideas for alternatives are: A) Just leave them there, open to the air (is that bad?) or B) Try to find some sort of little plug that will just slip on to the end of it and stop air from going in or out.
Any other ideas are appreciated! Thank you in advance!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hooker 2055 on a car with no AIR?
Cut them off, drill them out, tap them, and put pipe plugs in.
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Seems like a lot of work. Is it possible to cut the pipes and bend the end over?
Good thing about the Hooker 2460 is that they have no AIR plumbing.
Wish Hooker had the option to exclude AIR plumbing from the 2055.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the down side with the hooker 2046's is that the hooker y pipe is crazy expensive, its either fork out the cash, or have a y pipe made at an exhaust shop. and i think the hooker pipe goes from the 3" collector to a 2.5 in pipe too.
Engine: 305 LG4
Axle/Gears: 3.08
Thanks for the replies, I'm sure I'll figure something out if I order them. I agree with you peter, I wish you could get the 2055's without AIR. And I did already look at the 2046's, but the y-pipe is hard to find and expensive when you do.
I wish I could get Dyno Dons! But shipping to Canada is just crazy, and I just can't justify having a quarter of the final price spent on shipping.
Just want a final answer on this: is it bad to leave the AIR tubes open?
Thanks!
Thanks!
Engine: 383 Carb
Transmission: 4L60
You could leave the tubes on if you capped the ends or maybe left the check valves on. Leaving them open isn't an option.
Transmission: T700
That's a bummer. You'd think Hooker would bolt on, rather than weld, the AIR fittings like the OEM.
Engine: 383 Carb
Transmission: 4L60
Welding is cheaper on headers, and screwing-in is cheaper on manifolds.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Apeiron
Cut them off, drill them out, tap them, and put pipe plugs in....
Car: 85 Camaro Z28
Engine: 5.7 TPI
Can the cut, tap, plug method be done while the headers are still mounted to the engine in the bay?
1992 Trans Am
May 10, 2023 07:19 PM
