welding in AIR into non AIR headers?
can i weld in the stock AIR smog fittings into normal headers? or could i possibly custom route the smog pipes into normal headers? has it been done or could it be done? im assuming it can, it cant be that hard.
Oh and also are there any headers that I can run with the stock Y pipe? i dont have enough money to buy an aftermarket y pipe, only enough for just headers.
1991 350 TPI, thanks guys
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: welding in AIR into non AIR headers?
Welding on bungs for the AIR fittings will be really easy...
If your going to run headers your going to need a new y-pipe that matches the bends of the collectors and flanges... start saving get everything you need then do the swap.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Even though you can put AIR tubes on, that doesn't give the headers the CARB/whatever exemption #, so they aren't truly legal, if the Inspector pays attention.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Yeah only california is tough about **** like that. You need a special # to indicate it passed the emission requirements in California. I took a whole course on their restrictions and legalities...and it's absurd. Anything labelled "for offroad use only" is completely illegal and can potentially get your car impounded for it.
Car: GTA
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Ah couldn't remember the group that does the reviewing, thank you for that, was driving me nuts lol. CARB EO #.... Must be attached to the parts, or under the hood somewhere afair.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
