Headers, WHich ones will fir a stock l98 350?
Old Mar 1, 2012 | 04:50 PM
Demonic13's Avatar
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
Hey guys I have a 1991 Camaro Z28 with the stock L98 350. I want long tube headers. All the searching I do takes me to the V6 threads. I just want long tube headers to throw on my vehicle right into cats. I am in PA and no muffler is needed on this this so What headers will fit? I would like the to have the 3" diameter collector. Thank you.
Old Mar 1, 2012 | 10:24 PM
Keegan84's Avatar
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Re: Headers, WHich ones will fir a stock l98 350?
Hedman headers 68460, they are the cheapest you will find for LT's. Listed for 179 on summit, also they are the 3 in collector.
Old Mar 2, 2012 | 07:52 AM
Demonic13's Avatar
Originally Posted by Keegan84
Hedman headers 68460, they are the cheapest you will fun for LT's. Listed for 179 on summit, also they are the 3 in collector.
Thank you but I don't know if this matters. I don't have the LT block I have the L98. Would they still fit in my 91 Z28 L98 vehicle? Thank you.
Old Mar 2, 2012 | 09:06 AM
Keegan84's Avatar
Car: 84 trans am
When I say LT's I mean longtubes. I don't think it will matter, but I am not an expert.
Old Mar 2, 2012 | 09:17 AM
Demonic13's Avatar
Ok I will ask summit to be sure. I thought you meant the LT1 motor. Sorry about that and thank you.
Old Mar 2, 2012 | 10:20 AM
Demonic13's Avatar
I am now running into another problem. I contacted Summitracing tech Support about getting LT headers for this vehicle. They stated, If I got LT headers. I would have to run a Y pipe to keep the proper blow back that keeps the valves properly lubricated. and the o2 put would only read 1 back and cause the to not run lean enough or too lean. I don't remember what exactly they said. Anyone encounter this problem and find how to fix it? Thank you.
Old Mar 2, 2012 | 10:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
None of that is true.
Old Mar 2, 2012 | 10:33 AM
Demonic13's Avatar
Well I told him I was just running the headers ring into cats separate. no pipes or mufflers. Would that play a factor?
Old Mar 2, 2012 | 10:34 AM
Demonic13's Avatar
Please advise on how its not true. I am really weary about doing this now. Thank you.
Old Mar 2, 2012 | 10:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's no room for cats with long tubes, especially with a 700R4.
Valve lubrication doesn't depend on any exhaust effects. The stock O2 sensor setup only reads one side of the engine already. 68460s don't have an O2 sensor bung, but as long as you mount one close enough to the collector it will work fine. Use a heated sensor if you're worried about it.
Old Mar 2, 2012 | 11:40 AM
Demonic13's Avatar
That's what I had planned to do in the beginning. I will weld a bung in and use a heated. This info came from there tech support they should know this stuff. Are there and mechanics/engineers that have dealt with this to verify if the information is correct or not? I need facts not opinion. Not saying what you are saying is opinion I really want results. I don't want to be wasting money. Also if the Cats are welded up to the 3" collector how will there not be room? Thank you.
Old Mar 2, 2012 | 11:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Crawl under your car and have a look where the collectors are going to be.
Old Mar 2, 2012 | 11:58 AM
Demonic13's Avatar
Will do thank you. Also if I do this and I reach 65-75 mph on the highway the car wont chock or make any kind of noise do you know? I was also told this by summit. Thank you.
Old Mar 2, 2012 | 04:06 PM
Demonic13's Avatar
Sorry what I meant was,"Also if I do this and I reach 65-75 mph on the highway the car "will" chock"
Old Mar 6, 2013 | 11:47 AM
Demonic13's Avatar
LOL it only too a year. Just an update. i ordered these headers only to find out I have straight heads and not the angles aluminum heads these call for. They do not fit the stock L98 model that's official.
Old Mar 6, 2013 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I have them on straight-plug heads.
Old Mar 6, 2013 | 12:32 PM
Demonic13's Avatar
I stand corrected
Old Mar 6, 2013 | 12:38 PM
Demonic13's Avatar
I am going to see what is stopping them from fitting.
Old Mar 6, 2013 | 12:39 PM
Demonic13's Avatar
I was told they will bolt up. the problem is that they would cover the spark plugs and you will not be able to get them out or but a spark plug wire on them. How did you get around that?
Old Mar 7, 2013 | 12:51 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Forget LT's, you need these:
No plug or wire problems
Old Mar 7, 2013 | 06:51 PM
ROCrow71's Avatar
Car: 91 Camaro RS
Engine: 383 Stoker
Transmission: 350 Turbo
Honestly it sounds like you should forget the LT's and go with shorty's. Not trying to be a *** anything. But it would make life much easier for you. If you do go with LT's be prepared to spend some coin if you can't run the exhaust yourself. I just done my LT's with dumps before the rear axle. I spent a lot of fab time doing this project to get a good clearance.
And you will not see much, if any gain between shorty's and LT's with a stocker.
In short... Stay with shorty's
Old Mar 8, 2013 | 07:46 AM
Demonic13's Avatar
Thanks man That's what I am doing shorty's until I run the motor in the ground and do an LS swap. just wish I knew this with out buying the LT's first. I am selling them now if you guys know anyone that wants them. They come with collectors/reducers. $120.00 or best offer: Shipped.
Old Mar 8, 2013 | 10:41 AM
NoCrash's Avatar
What headers and y-pipe combo is that in the image? Would you make and sell y-pipes for the Hedman 68470 or the Hooker 2460? Good source for 3 inch y-pipes are hard to find.
Daryl
Old Mar 8, 2013 | 10:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those are Dyno Don brand.
Old Mar 8, 2013 | 12:25 PM
NoCrash's Avatar
So that's why I could not find those headerS at Jegs or summit! Very, Very Nice!!!
Old Mar 8, 2013 | 10:53 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Dyno Don makes Headers for dual cats cars also..You car will run in the mid to low 13's
Old Mar 9, 2013 | 05:05 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Can't go wrong w/ Dons Headers.....
Old Mar 14, 2013 | 10:44 AM
Dyno Don's Avatar
Old Mar 14, 2013 | 11:16 AM
87_firebird_87's Avatar
Car: 1987 firebird formula
Axle/Gears: stock with 373
I have they on my 87 firebird formula 350 68460
Attached Thumbnails Headers, WHich ones will fir a stock l98 350?-img_20130227_172409.jpg   Headers, WHich ones will fir a stock l98 350?-img_20130226_165344.jpg   Headers, WHich ones will fir a stock l98 350?-img_20130311_133938.jpg
Old Mar 14, 2013 | 11:20 AM
me too
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
