Hooker 2460 Copmpetition headers
Old Mar 5, 2012 | 11:19 PM
NeNick95's Avatar
Engine: 5.0 TBI
Wanted to know if anyone has install the 2460 hooker headers on their firebird or camaro.Want to know what I should predict, such as clearance and etc.Also, would like to see pics and maybe some quality videos.
Old Mar 6, 2012 | 10:57 AM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
Re: Hooker 2460 Copmpetition headers
Im going to be doing some engine bay work this afternoon so I will go ahead and make a video.
Biggest thing was grinding down the lips on the openings in order to make a good seal. The gaskets that came with them pretty much suck.
Also some brake lines on the drivers side were pretty close so I had to bend them out of the way.
Take off the starter also (duh)
Old Mar 6, 2012 | 08:58 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Hey there iron - while you are at that, could you also get me a measurement on how far the passenger header extends from the head face?
I have a rhd conversion with the steering column going right through that area, wondering if there's clearance for the 2460's.
Old Mar 7, 2012 | 03:16 PM
Engine: HSR L98
Axle/Gears: stock
Might take a little longer then expected. Teenage girl ran into my front left. Nothing major but its at my dads shop waiting till this weekend to fix.
Old Mar 7, 2012 | 07:40 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
So you got her number
Old Mar 10, 2012 | 03:30 PM
Engine: HSR L98
Axle/Gears: stock
psht If only I wasn't so angry at the moment haha.
Here is a picture of 2460's with the lip. What I did was grinded down the lips until flat and flush.
Old Mar 24, 2012 | 04:46 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
that was a bad move grinding down the lip, your'e supposed to leave it there because it helps make a tighter seal around the exhaust port, now the gaskets will be blowing out a lot sooner
Old Mar 24, 2012 | 07:22 PM
Engine: HSR L98
Axle/Gears: stock
Nah my lip was literally 1/4 of an inch high and uneven across the entire thing. If I didn't grind them down at least some when I put the bolts in it would have bent the plate.
I ground them down to around 1/16 to 1/8 of an inch and tacked on half moon washers to prevent the plate from cracking. My headers have a great seal and Im proud I did them all by myself lol.
Old Mar 25, 2012 | 05:07 PM
oh ok thats good i thought you ground them down completely flat, a little meat on theres good for the seal
Old Mar 25, 2012 | 05:45 PM
Camaro82Z28's Avatar
Car: '82 Z28
Engine: Dart 406 ci
I had no problems installing mine and went in quite easily from the top. However, all my smog equipment is removed.
Old Mar 27, 2012 | 01:11 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
What's the difference between the Hooker 2055's and 2460's? Is one better than the other?
Old Mar 27, 2012 | 06:08 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
2460s are slightly heavier and sturdier. They do NOT include a Y-pipe. There is a Y-pipe sold separately for them that is awful. The 2055's include a y-pipe, and it's one of the best off the shelf y-pipes available for our cars. Generally the 2055's are the better option.
Old Mar 27, 2012 | 08:07 AM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I have the 2460 headers And they tuck in perfectly.....I agree on the y pipe not being up to par though since mine would not even seal on the driver side flange......I'm gonna see what I can do with it again once I put my engine back together and reinstall the headers.....these prolly would not have been my choice of headers if I wouldn't have gotten the deal I got on them.....the y pipe is also pretty costy and is only 2 1/2 inch diameter
Old Mar 27, 2012 | 11:35 PM
Coprice 9C1's Avatar
I just installed ceramic coated 2460's on my 83 305 TA. They dropped in fine. I used Mr Gasket aluminum gaskets and didn't touch the flanges on the headers at all. Plug access isn't too bad, although there are several plugs that I had to snug up with an open end wrench. Plug wires are close in spots, but the ceramic coating seems to help keep them from burning. I recommend a reduced head header bolt. I used a Dougs Y pipe and it bolted up like it was made for it. I had to modify the big rear AC bracket, but it was just a cut/grind/file thing.
So far I can't complain too much, but my car is still in the build stage (no doghouse, weather stripping, etc) and I haven't been able to drive it any further than up and down the driveway.
I've had other headers on other cars in the past, and this combo is the first that bolted up in the garage without a trip required to the muffler shop afterward. Ceramic coating is a must in my opinion. The stainless Edelbrocks that I had on my LT1 Caprice looked like crap after the first time I ran them to warm up, and they took forever to cool off.
Old Mar 28, 2012 | 04:25 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Is that a Dougs D901 y-pipe that fits the 2460's? Just want to know for my research.
Old Mar 28, 2012 | 07:37 AM
Yes, that's it. It fit great. It hangs a little lower than the K member, but i didn't mind because this car will remain stock height.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
