1990 IROC-Z 5.0 Auto Headers W/Magnaflow Cat Back
I'm about to buy a 1990 5.0 auto IROC w about 90,000 miles on it. This was the previous owners 3ed car, and it was babied. He installed a K&N air filter system, headers and a magnaflow cat back system. I don't know any more details than that. My question is, approx. how much horse power does the engine produce now with the current setup?
Re: 1990 IROC-Z 5.0 Auto Headers W/Magnaflow Cat Back
Is whp measured at the crank or the rear wheels? If it's measured at the crank, what percentage would be lost at at the rear wheels?
1 Post
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
240 to the flywheel.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Well how do you know? What headers did you use? I've seen a 89 Iroc with a full exhaust system run 13.80's @ 102mph 20 years ago
Ok, I'm new to all this. Air intake, headers, cat back exhaust and tune should add about 50whp? When you say "tune", are you talking about adding a chip and running the car on a dyno, or just changing the spark plugs and so forth, or what? Also, how much should it cost?
If you haven't cut out the bottom of the air box, do it. It's worth about 5hp and the engine is breathing better.
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Whooaa. 50HP? That sounds excessive. People do complete head or header swaps to get that kinda power.
I always thought that a good re-run of exhaust is like a 10-20hp kinda deal. Not 50...
Not saying it isn't possible. Just stunning.
That's because they don't use 1 3/4 Dyno Don's headers, dual cats, 3in cat-back, 89-92 G92 5.7 350, free flowing intake and a tune. Get it?
For instance...I am running hookers, with true dual out on 2.5in to two Thrush mufflers..your opinion? (I ranged that about 25hp)
1 Post
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
wow the fail is strong in this thread...
