My true dual fix
Old Apr 30, 2012 | 09:31 PM
whitez406's Avatar
My true dual fix
the spohn crossmember sucked and since the car is lowered i would had about 2 in of ground clearence so i started fabbing this crossmember to go up inside the rails. i can run the exhaust completely straight so ground clearence will be awesome. still gotta fab the torque armmount and weld on driveshaft loop but its def worth it ill post pics when its completely finished.
Old May 2, 2012 | 07:53 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: My true dual fix
Great job fabricating this. I'd love to see how it all works out.
Old May 2, 2012 | 08:46 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Interesting my exhaust hugs the bottom and s; far hasn't grounded.out
Old May 2, 2012 | 10:03 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
very good looking crossmember, looking forward to seeing some install shots (especially with the exhaust)
Old Jan 13, 2013 | 05:22 PM
whitez406's Avatar
sorry guys i gotta get finished pics. It turned out pretty good my cars really low and with lovely pa roads it has yet to hit here only the mufflers hit so far.
Old Jan 18, 2013 | 10:37 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
So where do I send my payment to? lol excellent fab skills!!
Old Jan 19, 2013 | 02:18 AM
stickySC's Avatar
Car: 03 Gmc Sierra ,85 camaro, astro
Engine: 305,
Transmission: a4
did you use tubing or round stock? Thats sweet, Ive been thinking about making one of those.Would be so much easier if I had my hands on one, so i could reverse engineer one, Would be alot easier. post some more when you get it fab'd up. a bar napkin print would be nice 2. Dont quit recall, but im thinking the ones ive seen used square tubing for the cross section. is that what was causing the clearance issues?
Old Jan 26, 2013 | 01:01 PM
whitez406's Avatar
i used roll bar tubing. i made everything out of round stock except i reused the crappy spohn driveshaft loop. Im running a true dual 3" i made with mandrel bends and so far it hasnt hit anywhere and the car is lowered about 2". The only problem i have is the mufflers hit so im going to use a piece of 4" exhaust pipe and cut it down the center and basically cut the floor out and make "tunnels".
Old Jan 26, 2013 | 01:35 PM
whitez406's Avatar
The first picture is the spohn crossmember. Imagine trying to run a 3" under it with clearence. I need to get better pictures because the pictures make things look both crooked and the exhasut in the pictures appears low but its not its just the way it bends.
Old Jan 27, 2013 | 03:41 PM
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Sweet nice work!
Bubbajones_ya
Jul 6, 2024 08:32 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
