stock lg4 cat converter bright red and real rough idle
Old May 23, 2012 | 11:27 AM
Slowpoint0's Avatar
Car: 1986 t/a
Engine: Lg4 305 carb
Transmission: 700r4 auto
Axle/Gears: 2.73 posi
now that its finally running,
when i started it up today it started right up, but whole car shook bad, after it warmed up it seemed to idle ok, but when i gave it any gas it bogged and popped, cloud of smoke came out could smell fuel, looked underneith car and my cat converter was bright red..
with out going to a shop how do i adjust the air/fuel ?? its a stock engine with qjet carb lg4 305. stock manifolds, y pipe, and cat with Dynomax 2 1/2" cat back
Old May 23, 2012 | 11:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stock lg4 cat converter bright red and real rough idle
If you're dumping that much fuel it's a matter of repair, not adjustment.
Old May 23, 2012 | 11:47 AM
Slowpoint0's Avatar
Car: 1986 t/a
where would i start, carb rebuild? car has 150k far as i know carb never been touched
Old May 23, 2012 | 01:28 PM
Slowpoint0's Avatar
Car: 1986 t/a
So before cat started getting red.
I had a leak in the flange to the new cat back. I had it fixed (welded) no more leak.
Before leak, it idled right, ran smooth, 500-550rpms idle in drive, in park about 750-800rpms!
Now with glowing cat, idle in park (after warmed up) is around 1100-1200,
Idle in drive is around 800-900. Car shakes, bogs and pops when you hit gas and no acceleration.
Also I got the bog run with key turned off..
(I'm a month old Virgin to f-bodies, and man am I learning things)
Iv been reading alot of posts to try and fix and figure out as much as I can on my own..
I was told cat is clogged no good? I have headers and y pipe (not installed yet) I'm going to get a magma flow converter when headers get done!
What other reasons would stock cat glow???
Old May 23, 2012 | 04:20 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I just fixed some exhaust leaks before the cat and now my car runs like garbage. It shook like crazy and had no power. Turns out the cat was bad and I have a new one in the mail
Old May 23, 2012 | 07:08 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
if its glowing red it clogged cut it out and stick in a straight pipe.
Old May 23, 2012 | 09:48 PM
Slowpoint0's Avatar
Car: 1986 t/a
ok i took down my exhaust, removed cat and put up test pipe to test it, huge difference in power and idle, my new magnaflow cat is on its way to replace this bad one.. headers and new y pipe going to go on when new cat gets here!
jaridjohn
Jul 8, 2024 03:49 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gta power
Aug 13, 2015 06:15 AM
Bradsaundry
Aug 12, 2015 12:34 AM
