Magnaflow muffler
Old Aug 8, 2012 | 09:00 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Magnaflow muffler
I have a 1986 trans am it originally had a 305 tpi before I took the motor out I went to a performance shop and had a muffler put in with rectangular tips the piping from muffler to cat is stock, I then replaced the engine with a '89 350 tpi and have slp headers with cat now the problem I have is the exhaust makes a funky noise when you get to like 5k and above to try and describe the noise is like a humming noise with metal why doesn't my magnaflow sound like the rest of the youtube videos with similar set ups I currently have posted for sale my cat back to go in a different brand of exhaust I like magnaflow but this us a disappointment to me
Old Aug 8, 2012 | 09:19 PM
SinCityLocal's Avatar
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
Re: Magnaflow muffler
I have a Magnaflow (2-1/2") 2 in 2 out that I'm running.
I have no strange noises.
Maybe pull the muffler to check if something has come loose internally.
Old Aug 8, 2012 | 09:39 PM
DiabloWS6's Avatar
Thats what I'm thinking i know magnaflow has lifetime warranty maybe I should have returned for a new one
Old Aug 8, 2012 | 09:53 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
check your heat shields.
Old Aug 8, 2012 | 09:55 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How is your cat? They make a big impact on exhaust sound.
Old Aug 8, 2012 | 11:08 PM
DiabloWS6's Avatar
The heat shields are not lose
Old Aug 8, 2012 | 11:11 PM
DiabloWS6's Avatar
I checked the cat visually , it came with the slp headers I bought off craigslist supposedly its a high flow cat it is bigger in size compared to a stock one wich I have and the insides are still in tact
Old Aug 9, 2012 | 06:23 PM
Axle/Gears: 3.909
Is it possible something was dropped and fell into the exhaust during your engine swap?
Old Aug 9, 2012 | 06:27 PM
ghost91's Avatar
Car: 1991 Camaro Z28
What size intermediate pipe you running?
Old Aug 10, 2012 | 12:49 AM
DiabloWS6's Avatar
It is posible but I'm prety sure nothing that could obstruct
Old Aug 10, 2012 | 12:52 AM
DiabloWS6's Avatar
Everything is stock, the muffler to tail pipes is aftermarket + the headers
Old Oct 31, 2012 | 12:18 AM
DiabloWS6's Avatar
I found the issue is the rubber hangers on the rear and the one that's on the transmission are dry rotted and make it hang lose and is rubbing somewhere over the axle and thus making that wired noise i hear
Old Oct 31, 2012 | 08:34 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Thanks for the up date and letting us know what the problem was.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
