manifold to colector leak
Old Aug 24, 2012 | 07:11 PM
bookoorootoo's Avatar
Car: 86 z28
Engine: 305 l
Axle/Gears: 383
i have a very annoying exaust leak thats been getting worse from the manifold to collector, i brought it in to the shop and they said theres no gaskets its a flange fit, they wanted to cut a perfect exaust system, realign and weld for 90$ an hr....F that. could i just try to tighten it back up? its only the drivers side. suggestions?
Old Aug 27, 2012 | 03:10 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: manifold to colector leak
I've never seen a flange that you couldn't buy a gasket for. Check out summit racing and get some of the nice (expensive) multi layered metal ones. It'll never leak again.
Old Aug 27, 2012 | 04:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If your using cast iron manifolds the surface where the Ypipe collector mounts to could be rusty and pitted causing your leak. It may need to be removed, inspected and resurfaced or replaced..
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
