How can I make my cutout sound better?
Old Oct 11, 2012 | 10:07 AM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
When I don't have my foot in it there's an annoying chirping kind of sound. Someone told me to put a cherrybomb after the cutout but I'm not sure I have enough space, any suggestions as to how I could fix this?
Old Oct 11, 2012 | 11:53 AM
BADNBLK's Avatar
COTM Editor
Re: How can I make my cutout sound better?
IIRC the dougs cutouts are a sliding plate style? right? I have a QTP, and it uses a butterfly valve like a thottle body. When it was closed it would make a light "ting,ting" noise as the edge of the valve hit the lip on the aluminum body. I used a high temp silicone, and applied a thin line on the tops and bottoms which solved that noise.
Not sure if that plate on your dougs set-up could make contact anywhere when opened and closed, but I would look at where it is coming from as a first step, before planning on muffling your exhaust cut-out... defeats purpose
Old Oct 11, 2012 | 03:55 PM
Engine: 5.0 L03 V8
Yes, its the sliding plate style. That's a good way to fix that problem but I think I'm experiencing a different noise. I dont want to make the car quieter I just dont like the sound it makes when the pedal isn't mashed. I'm looking for something that wont take up a lot of space and wont muffle it too much, possibly like these magnaflow race series ones http://www.magnaflow.com/02product/0...p#racemufflers
Old Oct 11, 2012 | 04:58 PM
Guest
Guest
Posts: n/a
How about not having it open when your not in it trying to impress ppl.
Old Oct 11, 2012 | 06:25 PM
BADNBLK's Avatar
COTM Editor
So your plan is to put a muffler on the cut-out you installed to by-pass the muffler?
Old Oct 11, 2012 | 06:45 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
lol!!!! how about putting about 10-12 inches of exhaust pipe after the cut-out? you dont want a muffler there. i agree it defeats the purpose.
Old Oct 11, 2012 | 08:10 PM
Engine: 5.0 L03 V8
nah, I like it loud and its quiet when its closed so that didnt help me.
Old Oct 11, 2012 | 08:14 PM
Engine: 5.0 L03 V8
When you put it like that it just seems like tryin to make me sound dumb. You must not understand my question.
Old Oct 11, 2012 | 08:28 PM
Engine: 5.0 L03 V8
That might work. I'm not trying to defeat the purpose and make it quieter I just want to stop the annoying chirp. I do want a muffler there if it stops that chirp without radically dampening the sound of the car. Now I just have to find one that fits the criteria.
Old Oct 11, 2012 | 08:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ive cured exhaust drone by putting a smaller section of pipe into the very end of a pipe, the lip causes a small turblant area, if your section of pipes goes into not over the cut out end, it would be a good first choice.
Old Oct 12, 2012 | 12:14 PM
BADNBLK's Avatar
COTM Editor
Not trying to make you sound dumb, makes no sense to put any muffler on the outside of a cutout.
I think that you should look at the root of the "Chriping" noise. I can't imagine it is the exhaust gas pulses actually making the "chirp" noise. I have to imagine the only moving part... the blade is moving when not in a closed position. Light thin metal on metal movement will typically make a chirping noise. You might not need to add pipe, or muffler or anything else to hide the noise, but maybe you can solve the noise and use the cutout as it was intended, or might even find a problem with it that should be warrantied.
Old Oct 18, 2012 | 09:35 AM
Engine: 5.0 L03 V8
It doesnt seem like a metal on metal sound. I'll try to take a video and see if you can hear it.
Old Oct 18, 2012 | 09:38 AM
Engine: 5.0 L03 V8
my turn down goes over the cutout I'm not sure if I could put a smaller section into the turn down
Old Oct 18, 2012 | 02:38 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
So it only does it with the cutout open?
My first suggestion would be to unbolt the electric portion from the cutout itself. 3 bolts and simple test. Should atleast pinpoint if the problem is in fact in the valve portion.
Might be useless to do that though, dont think it could be anywhere else.
Old Oct 18, 2012 | 05:42 PM
Engine: 5.0 L03 V8
I'll give it a try
Old Oct 26, 2012 | 11:31 PM
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
Build a motor that moves enough air to sound good with a cutout. An L03 ain't gonna sound "good", no matter what exhaust is on it
Old Nov 2, 2012 | 01:07 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Don't run cut outs LOL! I have never head a car that had cut out's that did not have some sort of and exhasut leak just just sounded funky. Looks like the cut out setup is done nice on your car, but I'm just not a fan of them.
92camaroJoe
Jul 29, 2023 07:57 PM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
