3 sets of headers. none work
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Heddman long tubes - major clearance issues
Hooker long tubes - even worse
flow tech shorties- passenger side has clearance issues. mechanics claim my wires would burn on that side. cant get a finger between the header and...the A/C??
Ill have to call them back. This is getting ridiculous. Please remind me to never buy headers for a 3rd gen
any suggestions?
1987 IROC with Corvette 5.7 TPI motor. Stock heads
any suggestions?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 3 sets of headers. none work
Maybe its your car?
I have ran hedmans on mine, many other have as well. A ton of guys use the hookers as well.
Flowtechs are on quite a few budget cars too.
Maybe your front has been tweeked from an accident in its past?
Car: 1971 Camaro
Engine: 427
You say you have stokc heads.
Are they Stock Camaro cast iron heads, or are the corvette aluminum heads?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here you go...
Not the cheapest, but probably the best.
Car: 1971 Camaro
Engine: 427
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 87' IROC
any suggestions?
any suggestions?
Car: 1988 GTA Trans Am
Engine: HSR 350
X2 I had to get all new wires with the 90 degree boots with my heddmans. Also I agree you should try your self doesnt take many tools lol I was intimidated at first but it was fairly easy after the seized exhaust bolts
Car: 1989 Trans Am GTA
Transmission: M28 T56
My 2055's dropped right in from the top.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Agreed...hedmans and hookers both slipped right in with 2 different motors over the years on 2 cars..no issues.
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I have slp 1 5/8 headers fit just fine no problems...dyno don headers are also good
hectre13
Aug 26, 2015 08:17 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
