Warped header fix
Old Jan 14, 2013 | 03:05 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Warped header fix
http://Instagr.am/p/UeawTQPKoL/
That's a link to my instagram of my warped header. I searched the forum,not many results in the same spot as mine.
So Here's the thing, I don't know someone who Can fix it, plus I don't really want to buy a new set I just got these in the fall. My car's been sitting since November. So I don't know how long it's been like that.
It blew my mr Percy header gasket in minutes.
So this being the best Internet website to go to, anyone know any tips or tricks to seal it without major modifications or hurting my pocket?
Old Jan 14, 2013 | 03:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Warped header fix
resurface the flange.
Old Jan 14, 2013 | 03:54 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Weld in a wedge to fill the gap.
Old Jan 14, 2013 | 04:55 PM
nhgator's Avatar
Car: 1985 T/A
Clamp it to a flat,strong surface and carefuly heat it and work the flange flat.
Old Jan 14, 2013 | 05:24 PM
Twin_Turbo's Avatar
cut the flanbge between the outer primaries and the center pair.
Old Jan 14, 2013 | 08:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Take it to a machine shop and have them slap it on the big belt sander till shes all flat.
Also, use felpro 1404 or 1405 header gaskets and 1" long bolts with a lil anti seize on the threads.
Old Jan 14, 2013 | 08:51 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
ive heard this before.
Old Jan 15, 2013 | 03:43 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
that seems like a good idea until you try to bolt it up to the engine and you find that one or both of the outer tubes has bent up/down/forward/backwards from where it's supposed to be and you can't get the bolts to start.. been there, done that, cross threaded the bolt into the head- but never got the t shirt..
is the header hitting the frame anywhere? are the bolts to long, and not actually clamping down tight?
try taking the gasket out and bolting it up tight and see what happens- if you can get it tight that way, then it will clamp down tight with a gasket in there.
Old Jan 16, 2013 | 12:45 PM
jaybdaboat's Avatar
No the header isn't hitting the frame. Everything is tight, the homemade y pipe that was made for me is horrible. But it was temporary. My mechanic says it looks like it pulled the header away from the engine block, and that a new y pipe should fix that. I'm getting one Friday or Saturday.
Old Jan 16, 2013 | 01:35 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I've done this before- it's the way to go! you probably didn't warp it....it was probably not right to begin with, but who would actually put it on a straight edge before you install it the first time? I do! too many of these new exhaust parts are NOT flat. i hate having to do things twice! bring it to a shop and get it belt sanded once. you will probably never need to get it done again.
Old Jan 22, 2013 | 08:59 AM
joshc's Avatar
Car: 1986 Trans Am
3rd vote for belt sander.
My buddy has an 84 Z28 he was always having problems with his header gaskets blowing out. He took to our local machine shop, they said they see this all the time. Trued them up on the belt sander and its been fine for 2 years. They recommended the dead soft aluminum or copper gaskets.
Old Jan 25, 2013 | 05:25 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Just a note you probably didnt blow out the percy gasket. Its aluminum so its a bit hard to actually blow it like a paper gasket. You def have a leak there but once you fix the warp i bet you can slap it back together with the same gasket and be golden.
Old Jan 27, 2013 | 03:46 PM
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Didn't know this was possible.
Old Jan 27, 2013 | 03:56 PM
Twin_Turbo's Avatar
Do you have the percys with the smooth sides towards the headers? Swap them around
Old Jan 27, 2013 | 04:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It looks warped pretty far. Hopefully there is enough material to sand flat. Else may need to bolt to head and cut flange to move it flat, then reweld together, then resurface at machine shop
Old Jan 27, 2013 | 04:41 PM
Twin_Turbo's Avatar
The inner bolt on the short side of the radius looks like it's cross threaded also.
Old Feb 1, 2013 | 04:09 PM
jaybdaboat's Avatar
The exhaust shop thinks it to warped to resurface. Uh oh
Old Feb 1, 2013 | 04:10 PM
jaybdaboat's Avatar
Actually I don't think it's pushed down far enough to even cover the hole
Old Feb 1, 2013 | 04:24 PM
hotrodln's Avatar
Engine: Lt1 in IROC
tell em to lean on it more while sanding- it'll go flat!
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
In that case i would find an old head, carefully bolt it on and cut flange. Use heat and bolt pressure to bring it straight and reweld flange together. Then resurface.
Or buy a new header flange and cut the tubes off and reweld a new flange on
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
apie2546
Sep 5, 2015 07:40 PM
scotrans am
Sep 5, 2015 04:26 AM
