another 2460 vs 2055. But I need a little help!
Old 02-25-2013, 11:07 AM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I'm trying to plan the exhaust set up for my 350 that's going in and i'm looking at either the hooker 2460's or the 2055's. I hear everyone complaining about how the y pipe for the hooker 2460's goes down to 2.5 inches. Can't the last foot just be cut off and replaced with a 3 inch pipe? My friend works at an exhaust shop and could do this no problem. Then the 2055 have a choked down y pipe at the collector, but 3 inch at the end. I also do not have the AIR system anymore. The 2460's are a little cheaper than 2055 are. My car will be making about 350hp at the crank. Any help or guidance is appreciated!
Old 02-25-2013, 12:22 PM
Guest
Guest
Posts: n/a
Re: another 2460 vs 2055. But I need a little help!
The 2460s don't come with a Y-pipe
https://www.thirdgen.org/forums/engi...er-2055-a.html
Old 02-25-2013, 01:46 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Honestly get the 2460's and the doug's D901 y-pipe. It bolts right up to the 2460's and is MUCH cheaper than the Hooker y pipe. I cut off the 2.5 outlet, grinded out some of the welding flash from where the pipes come together and welding up a 3 inch outlet no problem. I've done this on TWO different Camaro's with no issues. The 2055's are nice and I've had both sets (2460's AND 2055's) and the 2055's honestly were more of a bitch to get right than the 2460's.
Old 02-26-2013, 04:01 PM
Gsoleski's Avatar
Car: 1984 Z28
thanks i'll look into it. So is the y pipe for the 2460's or the D901 all 3 inch with the last foot or so being 2.5? Or is the whole thing 2.5"?
Old 02-26-2013, 04:12 PM
The yare 2.5 from both collectors into a 2.5 inch outlet. The outlet is VERY EASY to cut off and have a 3inch welded on.
Old 02-26-2013, 06:20 PM
Gsoleski's Avatar
Car: 1984 Z28
Did you buy a piece of curved pipe or make one?
Old 02-26-2013, 06:35 PM
Luckily I have a header shop here in town that sells individual u bends and I bought one to make it. Hoestly try your local pick n pull and ask them if they sell sections of exhaust pipe. Look for newer Dodges and Chevy trucks. They come stock with 3 inch mandrel tubing. I picked up enough tubing to do TWO cars for about 40 bucks at the one in my town.
Old 02-26-2013, 07:15 PM
Gsoleski's Avatar
Car: 1984 Z28
Do you think a 90 degree bend would work? like this one?
http://www.summitracing.com/parts/wl...5/media/images
Old 02-26-2013, 08:21 PM
That will work just fine but you might have to cut an inch or two off after the y pipe so it doesn't stick out so far. Should be fine
Old 02-26-2013, 08:27 PM
Gsoleski's Avatar
Car: 1984 Z28
thanks. appreciate the help!
anesthes
10-21-2020 03:27 PM
anesthes
FAQ Board
63
11-07-2005 08:10 PM
MattODoom
09-06-2005 05:15 PM
87Formula4bbl
01-06-2005 08:13 AM
Quick Reply: another 2460 vs 2055. But I need a little help!
