A question for people in texas
Old Mar 6, 2013 | 01:08 PM
Kurtis32's Avatar
Car: 86 camaro coupe
ok i have no catalytic converter on my car and i know its required for emissions, but since my car is over 25 yrs old it doesnt need to pass emissions. but i've been told i cant pass an inspection without it even tho its over 25 yrs old. so does anyone know if its illegal to not have a cat converter even with the car being this old?? thanks in advance
Old Mar 6, 2013 | 01:16 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Re: A question for people in texas
If your car came from the factory with a Cat, needs to have one to pass. That's how it is in San Antonio, I believe this is a Statewide rule though. I've passed before without cats, this time they told me that and I had to get cats put on. I guess its how strict the inspection station is
Old Mar 6, 2013 | 02:06 PM
Kurtis32's Avatar
dang ok, thanks man
Old Mar 17, 2013 | 07:29 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
They do not check emissions though, so your cat could be empty. Cut 3" holes at each end and slip a 3" pipe through it and weld it back on each end.
Old Mar 17, 2013 | 07:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
There is a visual inspection and an emissions test. At 25 years, you don't have to do the emissions test anymore. But the visual inspection still stands. Having a catalytic converter is part of the visual test.
Old Mar 17, 2013 | 09:22 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
That's the way it is here in Austin too, may be different on other parts of the of the state, but they do a visual inspection of the emission system. If they see anything obvious missing, they won't pass you. Here they even give you grief if you have a cone air filter instead of the stock breather!
Old Mar 25, 2013 | 11:39 PM
R/T-Z28's Avatar
It depends on the county. Only a few of the larger metro counties do actual emissions on all vehicles except antique. Most just do a visual like stated above. If you don't mind the smell you should just gut the converter.
Old Mar 26, 2013 | 08:12 AM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
You might be able to bypass this by getting antique plates. Altough I think there is certain criteria you have to meet for those as well.
Or you can just ask around about an inspection station thats cool, you'll pay a little more but you'll get your tag...
Old Mar 26, 2013 | 08:54 AM
lonestar7's Avatar
Engine: 5.7L TPI
I just got my 1988 Formula inspected here in Austin this Friday. No emissions test because it's over 24 years old, they did looked under the hood a little bit, all stock in there. But they seemed to spend a lot of time looking at the exhaust, especially around the cat. Don't know why, the exhaust system is pretty new and bone stock. Anyway, it passed it's first inspection since I bought it so I'm happy.
MustangBeater20
Oct 29, 2022 09:20 PM
hayesaw0210
Aug 23, 2015 11:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
