4 inch muffler recommedation..
Old May 20, 2013 | 04:14 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Im currently running the mufflex 4 in. system with the magnaflow race muffler. It is a little on the loud side. Im fine with it. And all my neighbors in my current neighborhood are cool with it.
im going to be moving into a H.O.A neighborhood soon. Id just like to have a couple of suggestions on some quieter 4' oval mufflers so i can kinda get mt ducks in a row.
I did a quick search, but didnt find much on the issue.
Old May 20, 2013 | 04:17 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 4 inch muffler recommedation..
Don't use the Hooker AirFlow one. I have that one and you can see straight through it. Maybe you can get one of those bolt on defuser tips that have baffles built in?
Old May 20, 2013 | 04:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
All 4" mufflers are basically loud. Only one that may have a shot is the spintech crossflow one, that mufflex sells in that kit. Looks like a stock type muffler except 4" in dual 3" out muffler.
Old May 20, 2013 | 06:31 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i need a 4in . in and out. the cones are something i can look at.
anyone using the the dynatech split flows?
Old Aug 20, 2013 | 03:36 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
i have one, its a straight thru design and is loud
Old Aug 20, 2013 | 04:02 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i talked to another member a few weeks back about this, he had the magnaflow race and went to a flowmaster.
heres a jegs link.
http://www.jegs.com/i/Flowmaster/389...arentProductId=
he said it was substantially quieter, but i havent talked to anyone else about it.
Old Aug 20, 2013 | 04:21 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
They sound amazing but oh my god are they loud.
It was only after I took it off one day that I realized how much it was actually muffling the volume, because before then I was thoroughly unconvinced it did anything at all. Im considering switching to a Hooker Aerochamber to quiet it down. they dont make those in 4 inch, though.
If I were you I'd consider running two mufflers in line or splitting it into two 3 inch pipes after the axle. The Flowmaster 50 is another idea, if you go that route be sure to post up a before and after sound clip because I'm curious about that one myself. I dont really like promoting the stereotype of [uneducated ignorant southerner] thirdgens and I think my car doesn't, except for the volume level.
Old Aug 20, 2013 | 06:53 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have a spintech 4x3x3 and it is the best sounding muffler I have ever had and I am nearly 50 years old and have had them all. It is amazingly quiet at an idle and part throttle but does get loud at WOT. I also have a 90 ZR-1 with a borla system that sounds about as well but the LT-5 cannot be compared to a regular SBC. It is an entirely different kind of engine but the spintech is awesome and I highly reccomend them.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
