3.1 to 3.4 with 3.4 headers?
Old Nov 5, 2010 | 03:35 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Anyone know? In California can you swap a 3.4 for a 3.1 legally (title update?) and then use the 3.4 headers legally because they are CARB approved? If so just how much "massaging" is required to make the 3.4 headers fit a '91 F'bird? Or could the 2.8 headers have the AIR port added so it all at least looks legal?
Old Nov 7, 2010 | 08:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 3.1 to 3.4 with 3.4 headers?
I dont know if the exhaust ports are the same on 3.1 heads vs 3.4 heads, but if they are, you can swap a 3.4L engine into your car with no trouble. Then you can use the 3.1L headers. Just dont say anything to the smog guys. They'll never know the difference. There is a tech article in the Tech Articles section from the front page of this website that describes the process.
Old Nov 7, 2010 | 08:45 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
yes the heads are the same
problem is if you use smog approved 3.4 headers the number on the headers will reflect that its a 3.4 and not the original engine wont it? they do take a good amount of massaging to get the 3.4 headers to work.
you cant just put the whole 3.4 in the car as its not original equipment, you might could get away with it with EVERYTHING from a 3.4 car but i doubt it
Old Nov 7, 2010 | 09:29 PM
Awesome-X's Avatar
Car: 87 Camaro
The heads on the 3.4 are exactly the same heads that are on all the 60v6's (2.8-3.4) so they would work just fine or you could probably just add that AIR port and they probably wouldn't see the difference. I'd go with the cheapest option
Old May 16, 2013 | 12:39 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
link to these California legal headers ? and they will fit on a 3.1 or 3.4 correct
Old May 16, 2013 | 12:57 PM
Kingsobieski's Avatar
3.4 has 02 sensors in the exhaust manifolds. 3.1 has a single o2 in the y-pipe. You'd need to have the holes sealed up where the o2 sensors go.
Old May 16, 2013 | 01:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Headers are Pacesetter 70-1206 but they are only legal for 2.8. Strictly speaking.
Old Aug 14, 2013 | 01:27 AM
KG427KG427's Avatar
Car: 1991 camaro
Kevin
Do you know any1 or any1 from California? Willing to install headers on my 3.1? Let me know the price and how long I would need to leave it
Old Aug 17, 2013 | 12:44 PM
Kevin91Z's Avatar
You'd have to talk to Dyno Don.
Old Aug 18, 2013 | 01:16 AM
KG427KG427's Avatar
Car: 1991 camaro
Ok ill try I thought he was v8 guy only
Old Aug 18, 2013 | 01:19 AM
KG427KG427's Avatar
Car: 1991 camaro
Ok so just have to fill up the whole on the 2.8 headers.
Is heat an issue and my car is a daily driver will this kill my mpg ??
I can tune it I have moates chip thing fasteddi burns for me
Old Aug 19, 2013 | 11:37 AM
Kevin91Z's Avatar
Don does many different things, and exhaust is one of his specialties. I know he doesnt have any room now if you're in a hurry, but he might be able to recommend someone else.
No, headers do not kill your gas mileage. If anything, they will help as the exhaust gas from each cylinder has its own tube to travel in instead of being bunched up in the small stock exhaust manifold.
Old Aug 21, 2013 | 09:54 AM
KG427KG427's Avatar
Car: 1991 camaro
I am in no rush, but would like to schedule something what is the best way to shoot him a message to get a responds at his convenience.
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
cking99
Sep 22, 2015 11:33 AM
