Camaro Headers ???'s
Old May 29, 2013 | 06:24 PM
dickeymoore's Avatar
Has anyone used Doug's headers on a 82-92 Camaro if so how do they fit or are there anymore headers that fit GREAT or is "DYNO DON" the best way to go?THANKS
Old Jun 8, 2013 | 09:13 PM
Snoopywasaga's Avatar
Car: 84 camaro Z28 LG4
Engine: 305 LG4
Transmission: 5 spd BW
Axle/Gears: stock
Re: Camaro Headers ???'s
Just installed a set of Doug's headers on my 84 Z28.
84 Camaro Z28 LT4 305, q-jet.
Doug's Headers. 3320-R
Doug`s Y-Pipe 776-D901
The fit was not difficult once I got all the brackets out of the way from the A/C and Pwr Steering. These are shorty headers and went in pretty slick given the space in the engine compartment. Bought the Y pipe as well which was easy to bolt on with a second set of hands helping. About the only problem is the location of the Y pipe isn't exactly as stock and the hanger for the cat was off by about 6 inches. I'm still working on it and will get the pipe bent to fit. The other problem was getting the A/C Bracket to work with the headers. Found a few posts for this if you have A/C. Overall not as difficult as I would have thought.
Old Jun 8, 2013 | 10:18 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I looked at all the problems each manufactor had and addressed them all in my design.
3/8th thick flanges, 1 3/4" tubes, ball and socket collectors, easy plug access, all spark plug angles, accessory brkt. ability, AIR tubes for direct connection and the best flowing Y-pipe...single or dual cats for connecting to stock cat(s).
Each set made to your order.
If you can find something better....you know what they say.
Old Jun 9, 2013 | 01:30 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
do you offer headers that have 1 5/8" or even 1 1/2" primaries for people that aren't trying to make 500hp?
Old Jun 9, 2013 | 07:39 AM
Guest
Guest
Posts: n/a
That is stupid...
evilstuie
Feb 28, 2016 03:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
