Can hooker 2055's fit an early third gen (ie 1984 trans am?)
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Just found a really good deal on 2055's. but will they fit?
Thanks!
Chuck
Thanks!
Chuck
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Can hooker 2055's fit an early third gen (ie 1984 trans am?)
why wouldn't they fit? the hookups for the emissions stuff might be in a slightly different location, but they still go on a small block in a 3rd gen F body..
Called summit and they said that it will not fit.... That's why I'm asking, but like you said why wouldn't they fit?
I'm calling hooker tomorrow
Just want to make sure...kinda stink if I buy this thing and installation becomes FUBAR.
Car: 1983 Chevrolet Camaro Z28
Engine: 5.7 SBC Gen1
Just make sure your motor mounts arent wasted. I had my passenger header hit the kmember badly, still could get it on with some wrestling but caused some vibrations.
Hmmm..... So would you still recommend them? Would you have installed them differently (i.e. - at a shop?)
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 86 Camaro
the difference might be in the hookup for things like the AIR pump tubes and the cat converter flange. Hooker might have gotten them CARB certified in a certain car with a certain engine and trans, so they might be technically legal and a direct fit on a TPI motor with a stick but will actually work just fine on a TBI motor with an auto..
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
I'llrocya
Feb 2, 2016 11:43 PM
