Hedman Headers and Y pipe
Old Jun 30, 2013 | 02:15 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Guys, got the hedman shorty headers installed and just loosely bolted up the y-pipe to find out the y-pipe is contacting the frame. Has anyone seen this and/or have any recommendations on have to fix it ? These are brand new headers and y-pipe, also installed new motor mounts.
Attached Thumbnails Hedman Headers and Y pipe-dsc05585.jpg   Hedman Headers and Y pipe-dsc05582.jpg   Hedman Headers and Y pipe-dsc05592.jpg
Old Jul 7, 2013 | 08:03 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Re: Hedman Headers and Y pipe
I've had the same set up for eight years, I ended up spacing the headman headers to the y pipe with @ 1/2 to 1' worth of summit 3' flange gaskets stacked together with the dead soft aluminum @ 1/8" thick flanges to make the necessary spacing to obtain the clearance you are looking for.The pax and drivers side require different thickness. This has worked fine w/o leaking. put a mildly built 350 in last fall @ 400 hp/tq and now do not have enough exhaust flow so I am installing a Dynomax 89009 true dual exhaust system. Good luck hope this helps
Old Jul 11, 2013 | 02:26 AM
Rabble's Avatar
I'm currently having the same problem with my headman shorties and Y pipe. I'm not very satisfied with their kit, sadly that's all the budget had room for. Their ball socket flanges are crap. A couple header bolts wouldn't go in without slightly dimpling the primary near the flange. Wish I had money for Don's headers
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
bamaboy0323
Sep 12, 2015 07:14 PM
89fast5oh
Sep 8, 2015 09:55 AM
