engine swap
Old Jul 1, 2013 | 01:39 PM
Race-Dave's Avatar
Car: 91RS
Axle/Gears: 373 4th gen
engine swap
Hey how's everybody doing. I'm swapping a 350 into my 91 RS, I was wondering if I can install the motor with the headers on or not. They're flotechs, and the transmission is a 700r4,I did not remove the Trans.
Old Jul 1, 2013 | 01:41 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Re: engine swap
Well why would you? It isnt to hard to install them after motor is in the car and then you dont have to worry about the extra few inches they stick out from the block which makes it a tighter fit trying to get the motor in the exact spot when you drop it in the first few times.
Old Jul 2, 2013 | 09:41 AM
85_ZED28's Avatar
Car: '85 Z28
Re: engine swap
Just lay them in place in the engine bay and lower the engine down. Then it's easy to just bolt them up!
Old Jul 2, 2013 | 06:50 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Re: engine swap
Are you talking about connecting the headers to exhuast pipes then lowering engine? Because that seems like it would be hard to manipulate motor and turn it much and i think he meant to connect the header to the actuall motor then drop it in.
Old Jul 2, 2013 | 11:54 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: engine swap
Put the headers on first. It can be done. Its easier to tighten up the bolts while on the engine stand.
Old Jul 3, 2013 | 12:04 AM
VincentZ28's Avatar
Re: engine swap
Old Jul 4, 2013 | 05:26 AM
Race-Dave's Avatar
Car: 91RS
Re: engine swap
Hey thanks for all the imput. I tried to install the motor with the headers on but couldn't line up the transmission. I installed the headers after I had the motor and Trans. bolted together. If the Trans. had been out I think it would of went in real easy.
Old Jul 4, 2013 | 03:34 PM
85_ZED28's Avatar
Car: '85 Z28
Re: engine swap
Nope, just placing the headers in the engine bay right before you lower it down all the way.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
