a good header option?
Old Sep 4, 2013 | 04:50 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
So I have been looking around for some headers and I ran across these:
http://www.jegs.com/i/Hedman/500/68481/10002/-1
I was wondering if anybody else though these would be a good option for a 92 Camaro with a TBI 305.
Note: I have swapped the stock exhaust pipes for a 3" flowmaster cat-back, but it still has the original catalytic converter which I THINK has a 2.5" inlet.
Old Sep 4, 2013 | 06:04 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: a good header option?
Yes, only if the headers have a 3" y-pipe to cat connection. Obviously you will need to get a factory replacement 3" cat.
The stock TBI/LG4 2.25" cat is pretty much a useless bottleneck on a 305 or larger - stock or not.
Old Sep 4, 2013 | 07:33 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I have the same flow masters u for w/hooker shorties. Very happy. I had headman long tubes on 78 TA SBC 355 & had lots of leaks at the block. They were great performing but I had to frequently re do gaskets which was a pita. If I had choice I'd go w/magnaflow exhaust. Good luck
Old Sep 7, 2013 | 11:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I'd personally go with either Dyno Don or Hooker 2055 headers. They are as close to "Bolt on" as you'll get and seem to be the favorite of the boards here. I personally run the Hooker 2055's and love them very much, mostly because I still have the emissions all hooked up. If you don't need emissions, then Dyno Don sells a set that don't have the AIR tubes.
Old Sep 8, 2013 | 11:27 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
frequently people will go buy headers THIKING they will just bolt on and be done.NOT THE CASE at all. most people have to bend,bash and/or completely re engineer them and then MAYBE they will be alright ,for awhile.to be fair ,you do get what you pay for.and because of that I would buy the very best headers I could lay hands on.IE dyno dons or hooker.and get the coated ones so they may last for a few years.BUT THEN theres the spark plug issue.you cant get to them.not to mention the burned wires . and you WILL need a starter heat shield. if you don't mind all this BS then by all means,go to it. but do be advised they come with their own issues that can be a challenge to your sanity.
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
Wvcamaro
Sep 4, 2015 08:38 PM
InfinityShade
Aug 22, 2015 08:00 PM
mustangman65_79
Aug 7, 2015 09:55 PM
