Mufflex Y Pipe + exhaust
Old Mar 30, 2014 | 02:41 PM
  #101
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
Re: Mufflex Y Pipe + exhaust
Sounded real good out in the open like that. Not as loud as your earlier clip. How do you like it now that you've run it a little bit 25th?
Old Mar 30, 2014 | 04:58 PM
  #102
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Ran it all day today, its a completely different feeling. It pulled hard up through 6200, consistent.
I have a rev video, I just have to try and load it...
Old Mar 30, 2014 | 05:41 PM
  #103
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
I cant wait to hear it.
Old Mar 30, 2014 | 06:11 PM
  #104
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Another LONG TUBE Broth-ren has joined our ranks.
Old Mar 30, 2014 | 08:16 PM
  #105
Axle/Gears: 4.10:1
Not the best, but there's plenty of summer left for videos to be had....
Old Apr 1, 2014 | 11:10 PM
  #106
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Ok, that sounded pretty loud.
Old Apr 2, 2014 | 12:32 PM
  #107
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
A lot higher pitched than expected.
Old Apr 2, 2014 | 12:40 PM
  #108
Axle/Gears: 4.10:1
Video quality isnt the best, it sounds much better in person.
Old Jun 7, 2014 | 08:14 AM
  #109
Axle/Gears: 4.10:1
With this new exhaust system, I gained 1 full second and over 10 mph on my time slip. from 12.97 @ 105.9 to 11.92 @ 116.7
I lost ground when I had to shift into 4th gear around 106mph. Time to look at new gearing.
Old Jun 7, 2014 | 08:43 AM
  #110
Mikey84z's Avatar
Car: '84 Z-28
Engine: 421
Transmission: Full Manual TH700R4
Axle/Gears: Stock w/Auburn 3:73
Wow, i've been out of the loop for a little bit. All this information will be put to good use. My Mufflex system just arrived this week with the Y-Pipe and 4" Flowmaster Cat Back. I'm hoping that i won't have too much trouble with the install. Thats a lot of pipe to fit under there. I'm also concerned about the pipe going over the axle. How did that go for you 25th?? Heck, i'm going to print out everything you did and use it for a manual...f-ing nice job!!
Old Jun 7, 2014 | 09:05 AM
  #111
Axle/Gears: 4.10:1
It actually fits perfect, I had to take one of the heat shields off. I thought about getting a panhard bar relocation kit but not really needed.
Old Jun 7, 2014 | 09:07 AM
  #112
Axle/Gears: 4.10:1
The most difficult part was "Notching" the transmission cross member. I have a pic somewhere, i'll post it. To compensate for structural loss, I took a small angle iron and welded it to the top half. Again, i'll post picture.....
Old Jun 7, 2014 | 09:09 AM
  #113
Mikey84z's Avatar
Car: '84 Z-28
Engine: 421
It looked to me that i might have to trim the heat shield a bit just by looking at it quickly. I'm thinking of wrapping the pipe with that heat shield crap before installing it since it's very close to the gas tank.
I'm away with the Army until Tuesday so i don't get to play this weekend...
Old Jun 7, 2014 | 09:58 AM
  #114
Axle/Gears: 4.10:1
This one indicates the crossmember installed, you can see the notch in the driver side. Passenger side only needed a notch on the front half of it, towards the engine.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
This one you'll see the angle iron I welded on the top.
[IMG][/IMG]
Old Jun 7, 2014 | 10:44 AM
  #115
Mikey84z's Avatar
Car: '84 Z-28
Engine: 421
Nice work. I have the torches and welder ready just in case i have the same issues. I'll be mocking it up this week. My engine mounts are a little older so they might have settled enough for me to avoid surgury. Time will tell..
Old Jun 7, 2014 | 10:49 AM
  #116
Axle/Gears: 4.10:1
Good luck to your project. Well worth it in the end!
Old Jun 7, 2014 | 11:02 AM
  #117
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Damn ... That's awesome ! ... I'm hoping a new exhaust system will get me about a half second in the 1/8th ... But I'm just gonna go with 3.5" seeing as I only have 310 cu. In. Lol ... Right now I'm runnin cheapo shorties with only 1.5" primaries with all crush bent BS exhaust system 2.5" y into 3" all way back to a crossflow ... I'm gonna go with some Hooker tuned length longtubes and either 2.5" true duals run down one side or a single 3.5"
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades. 24mpg @ 2500rpm hwy. 8.80@ 84mph 1/8th on street tires... 8.000's soon
Old Jun 13, 2014 | 01:47 PM
  #118
Mikey84z's Avatar
Car: '84 Z-28
Engine: 421
Well just got done doing the Mufflex install. The Y-Pipe was quite challenging but after a few test fits was able to get it installed properly without trimming the crossmember. After that it was a piece of cake. Drove it on the street for the first time in over 8 years yesterday and the sound from this sytem (w/Flowmaster) is amazing. The crew at Mufflex were super helpful as were all the tips i received from the folks on here. I don't have any pics available but could do some if anyone was interested.
On the down side i blew the gasket out of the back of the intake manifold on it's maiden voyage and pissed oil everywhere. No fear though, had the intake off last night in about 30 minutes and got the new gasket on lunch today. Should be going in no time, as long as this rain stops soon....
Old Jun 15, 2014 | 06:04 AM
  #119
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
great sounded car !!!!!!! I'll be ordering mine as I'm getting ready to put in a new motor thanks for the write up on this
Old Jun 15, 2014 | 07:51 AM
  #120
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
ive been contemplating going to a 4" exhaust with my turbo setup
Old Jun 20, 2014 | 06:22 PM
  #121
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Hello mufflex!! I dont think my lap top speakers are giving me much to go on.... How about an in-car vid with a nice pull next time your bored?
Old Jun 23, 2014 | 08:27 PM
  #122
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
We want sound clips bro. Heavy on the throttle.
Old Jun 23, 2014 | 09:18 PM
  #123
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Let's hear it!!! To all the haters of Flowmasters out there, nothing wrong with them!!!!
Old Jun 23, 2014 | 09:58 PM
  #124
Axle/Gears: 4.10:1
Ill work on getting that soon, id like to get a video of the speedometer and tach as I hammer on it.
Old Jun 23, 2014 | 11:37 PM
  #125
Axle/Gears: 4.10:1
Its all I have now, i'll get a better one up soon. Acceleration to top of 3rd. Had a soft shift into 3rd gear, I lost a little ground there..
Old Nov 20, 2015 | 10:14 AM
  #126
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I know this thread is old, but wondering how everyone is liking their long tubes and mufflex? I'm going to be installing L/T with the Mufflex y and 4" Magnaflow for my 383 to breathe. I think my Hooker 2055's are choking at the collector and not allowing my motor to fully exhale!
Old Nov 20, 2015 | 12:44 PM
  #127
Axle/Gears: 4.10:1
I noticed a drastic seat-of-the-pants difference in performance. I don't regret it, I also got the 4" MagnaFlow.
Old Nov 20, 2015 | 12:54 PM
  #128
Car: 1982 Z-28
Engine: 383
I'm also leaning towards the Magnaflow. Is the noise level too much for the street? The one where you are driving away it doesn't seem too loud.
Old Nov 20, 2015 | 12:59 PM
  #129
Axle/Gears: 4.10:1
It's more Throaty than loud. I'm sure if a cop wanted a reason to pull me over, he would cite me a noise violation. But haven't yet in 2 years that I had this exhaust
Old Nov 20, 2015 | 01:37 PM
  #130
Car: 88 IROC-Z
My setup:
Lts
Mufflex Y-pipe
nothing else, wide open
My WOT sound (with my FULLY worked intake) is similar to an angel screaming.
bamaboy0323
Sep 12, 2015 07:14 PM
iroczz89
Sep 12, 2015 04:55 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
