factory like tips
Car: 83 Z 28
Engine: LG4
Axle/Gears: dunno
factory like tips
Guys,
My 83 z will need an exhaust this spring. I really like how clean the factory exhaust looks. The tips don't protrude out the back and are almost flush with the sides of the car and the sips are clash cut and flared. Does anyone make an aftermarket set up that's similar?
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: factory like tips
Like these ?
http://www.ebay.com/itm/00748-Polished-Stainless-Steel-Camero-Exhaust-Tip-2-25-Inlet-7-75-X-2-Out-/360833793979?pt=Motors_Car_Truck_Parts_Accessories&hash=item54035ebfbb&vxp=mtr
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
I think he means like these... http://www.gtasourcepage.com/87Photo...asley87gta.jpg
You can just barely see them and they are cut parallel with the ground.
Transmission: 5-Speed Manual
Mine Are Factory,Is This Type You Mean If So The One's That 89 350 Shows In His Post Are The Closest Your Going To Get To The Factory Look.
Car: 83 Z 28
Engine: LG4
Axle/Gears: dunno
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just a heads up. If your car is equipped with dual mufflers as some early model were, you may have to consider how you wish to replace them.
BTW, I like the OE looks too, so when I installed my Hooker catback, I used the stock tail pipes.
JamesC
JamesC
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
gta892000
Sep 16, 2015 12:37 AM
Andrew Prakash
Sep 8, 2015 11:48 AM
