Long Tube Install Question
Old Feb 3, 2014 | 11:03 PM
berlinetta17's Avatar
Soon I am going to install a set of long tubes on my 305 berlinetta from 84. I am looking at Hedman Hedders 68460s. On summit racing, they say they are designed to fit the car as stock. Does this mean I wont need a ministarer or anything like that. I know I will need 90 degree plug wires. Im planning on getting header bolts, and a drill and tap kit incase a bolt breaks. Anything else I should know?
Old Feb 3, 2014 | 11:06 PM
Re: Long Tube Install Question
I am wanting to get an offroad y pipe, and a 3 inch pipe to dual dynomax race bullets.
Old Feb 4, 2014 | 10:04 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have those headers in my 91 rs with a 350. they are a little tight in some spots. but not too bad
Old Feb 4, 2014 | 10:40 AM
racerx520's Avatar
its been my understanding that in order to fit any long tube headers, you need a little "mechanical persuasion" with a hammer in some spots.
Old Feb 4, 2014 | 11:20 AM
Even with the tight fit you didn't need to change any parts? Which way did you put the headers in, top or bottom?
Old Feb 4, 2014 | 11:31 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I have hedmann longtube headers on my 350 and it is pretty tight but no persuasion was needed with the hammer. I do have a mini-starter though, but never tried to fit a regular one.
*EDIT* and my headers were put in when we dropped the motor in, meaning that we tied them up to the sides and dropped the motor in to bolt them up.
Old Feb 4, 2014 | 11:35 AM
So I will most likely need a mini starter then?
Old Feb 4, 2014 | 11:36 AM
Car: 1983 Z28
I would guess so, yes. But I can't say definitively.
Old Feb 4, 2014 | 12:50 PM
Guest
Guest
Posts: n/a
YES YOU WILL -NEED- A MINISTARTER!!! DO NOT EVEN ATTEMPT TO INSTALL WITH A STOCK 1.
-you have been warned
<---tried it and failed
Old Feb 4, 2014 | 01:55 PM
That sucks. Because I just got a new starter... I dont mind getting another one though. What starters are the most reliable?
Old Feb 4, 2014 | 01:58 PM
Car: 1983 Z28
Mine is just whatever Autozone handed over the counter, of course my car only gets driven once a week when it's not winter so idk. But it's been on there for....6-7 years now and is still turning like a new one.
Old Feb 4, 2014 | 02:18 PM
racerx520's Avatar
high torque mini starters are the way to go anyway when you put headers in. i have a new starter in with my shorty headers and after driving around for as little as 10 minutes, it will act like a heatsink and bind up refusing to start. i have to drive around with a 1 liter bottle of water, if it seizes up, i have to put a hole in the top of the bottle and hose down the starter. before spending $250 on a new starter though, i'm gonna try the starter cover, which looks like a tin foil bag that goes over it.
Old Feb 4, 2014 | 03:27 PM
Guest
Guest
Posts: n/a
Im using the $161.99 (WAS $150 last summer...) jegs mini....
Old Feb 4, 2014 | 10:51 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
This is what I bought for my long tube headers(Ed quay 1 7/8)
http://www.summitracing.com/dom/part...9540/overview/
Although when I had my hedman shorties I used a summit mini starter.
But the above starter was smaller and lighter and had way more adjustability
Old Feb 5, 2014 | 07:56 AM
yeah i have a mini starter. i put them in from the bottom up i believe.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
