Installing new headers
Old Mar 2, 2014 | 01:31 PM
pontiacdog's Avatar
Car: '86 Trans Am
I'm in the process of installing my new headers but I have problems torquing the bolts.
It's hard to fit any kind of tool between the header tubes, let alone a torque wrench.
The header is in place but I have no idea if it's tightened properly or not since an 11mm wrench was the only tool that I managed to use.
What do you do when this happens?
Here's a pic. It may look like there's plenty of room but actually there's not.
http://static.ylilauta.org/files/qv/...g/IMG_2566.jpg
Old Mar 2, 2014 | 06:35 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: Installing new headers
Picture is 404'd. I would guess just to get them as tight as you can. And then run the engine and see if they leak exhaust.
Old Mar 2, 2014 | 06:47 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
its the nature of the beast. no matter how much you tighten them, after the motor gets hot, then cold a few times. they're gonna be loose. might take a few times of retightening. 7/16" & 11mm are the same size. shop around for a couple different wrenches. you might find that different wrenches fit better. short ones fit better in the rear usually.
Old Mar 3, 2014 | 09:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Yes buy some different wrenches.
Also don't be afraid to bend or cut a wrench to make it work
Old Mar 4, 2014 | 03:27 AM
pontiacdog's Avatar
Car: '86 Trans Am
Thanks.
Also, another problem:
On the driver's side there used to be a black-painted metal bracket that holds the AC compressor and the fuel lines if I remember correctly (my car has AC on the driver's side).
The bracket was designed to be bolted on the stock exhaust header.
What do I do with it now that I have custom headers?
The O2 sensor is also in a different place now so I'll have to make a longer electrical wire for it but this is no problem I think.
Old Mar 4, 2014 | 08:53 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i think i know what your talking about?
instead of using a header bolt in that hole, (the front one correct?), find a spacer of the same thickness as the factory manifold and use the factory bolt. i've sacraficed a 1/2" drive socket as a spacer a few times.
Old Mar 5, 2014 | 08:18 PM
I have like every 7/16" and 11mm wrench, socket, and whatever else variety, known to mankind.
There's no "one" "universal" "magic bullet" solution. Just gotta try different stuff, different tools will work on different individual bolts. Nobody out here can predict what tools will work on your particular blots.
I like the socket idea. Never tried that for that exact alternate engineering. I've used alotta water pipe and such as that over the years. I guess it's just, what we each think of, or see sitting in front of us, first.
Old Mar 5, 2014 | 08:23 PM
I should mention, I have also been known to use socket-head bolts, in really ornery spots.
Old Mar 6, 2014 | 10:43 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Get some ARP 100-1109 bolts, they have a smaller head... 5/16th
Old Mar 6, 2014 | 11:09 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Originally Posted by pontiacdog
Thanks.
The bracket wouldn't physically fit on mine so it was necessary to cut part of it away. (The compressor was long gone on this one though.)
It would help if you filled out the details of your Thirdgen in your profile.
Old Mar 11, 2014 | 10:57 AM
pontiacdog's Avatar
Car: '86 Trans Am
I'm finding it impossible to fit the bracket, too.
Here's a picture to demonstrate.
http://aijaa.com/K0Xl0V
What do you think I should do? I can't really even remember what this bracket was for. I hope scrapping this part won't affect the installation of the power steering pump or the AC.
Old Mar 11, 2014 | 12:04 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have found the 3/8 head bolts easier to install
http://arp-bolts.com/kits/ARPkit-detail.php?RecordID=8
Smaller head
Old Mar 11, 2014 | 12:10 PM
Scorpner's Avatar
Engine: V6, V8
I don't have the AC compressor so I cut it off. If you decide to cut it, I would grab one from a junk yard in case you change your mind.
If I were keeping AC I would extend the header bolt and try to modify the bracket to reach. Something like a threaded rod with 3-4 nuts to hold everything in place, and then weld some metal to the bracket to reach that.
You could also consider a serpentine set up. They have braces too but some people leave them off.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
