OBX header install with lots of pics
Old Mar 7, 2015 | 01:49 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
So thought I would add the install process for me with these headers. To start with I had to remove the normal stuff. Plugs, starter, Steering shaft, Blower box assembly and my driver side coolant sensor.
Next I found that both sides went in pretty easy from the bottom. I could not get either side in from the top as I found a few others had. I also had to grind a little notch off a tab on the tranny that holds up the plastic flywheel cover to allow the header to slip by on the drivers side. Probably could have lifted the motor a little but this was easier for me.
I also had the typical bolt holes not lining up perfect on the heads. I just used a die grinder with a tungsten carbide bit to open the holes up. It was a pain to get right. Taking them in and out of the car a hundred times sucked.
I did grind a little off of the driver side control arm mount for clearance. I also had to grind the tranny cross member for clearance of the y pipe tubes.
Now onto the pics..
Old Mar 7, 2015 | 01:54 PM
seiplentz's Avatar
Car: 85 Z28
Re: OBX header install with lots of pics
First look
hole lineup
Old Mar 7, 2015 | 01:59 PM
seiplentz's Avatar
Car: 85 Z28
notch on tranny
Driver side
Old Mar 7, 2015 | 02:09 PM
seiplentz's Avatar
Car: 85 Z28
Driver side collector
Pass side collector
Old Mar 7, 2015 | 02:27 PM
seiplentz's Avatar
Car: 85 Z28
pass side cross member
If anyone wants to see anything specific let me know.
Old Mar 11, 2015 | 08:36 PM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
I can't believe they haven't made any improvements on these. Make sure it is not just the bolt holes that are off. I had to have the flange cut cause one of the tubes wasn't lined up well with the port in the head. Finally I said heck with it and went with a set of Hawks Stainless works . Learned my lesson
Old Mar 12, 2015 | 10:02 AM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
I've been wanting to order this set. How long did your install take? How did the rest of the install turn out? How much did you have to modify the exhaust to mate up to the supplied parts?
Old Mar 12, 2015 | 09:46 PM
seiplentz's Avatar
Car: 85 Z28
My install probably took me 30 hours as I took my time and I'm not a mechanic. Not sure about what you mean by mate up. I did not use any of the remaining exhaust. After the y-pipe that comes with it I added a pypes muffler and a 3" turn down. I will be adding the rest over the axle and back when I have more time. Spring is here and I want to drive it.
Old Mar 13, 2015 | 08:54 AM
crazymex83's Avatar
Engine: L98 TPI 350
I can't blame you for wanting to drive it now rather than later. I was planning to use the rest of the exhaust if possible so I wanted to know if you had to modify it much to fit it together.
I'm curious about the sound too but since you added a turn down I'm assuming it's louder than before.
Old Mar 14, 2015 | 05:35 AM
sabien's Avatar
Car: 91 Camaro
Engine: 355 Carb
Transmission: 5 speed
Axle/Gears: 342 Posi
Should have just went with "Dyno Don" headers.Mine fit perfectly and no problems with install. He's a member, look him up.
Old Mar 14, 2015 | 04:09 PM
seiplentz's Avatar
Car: 85 Z28
I am quite aware of his headers. I wanted stainless and long tubes. There only 2 options and it wasn't a big deal for the cost. All headers require some sort of work. A little filing of some bolt holes big deal.
Old Mar 14, 2015 | 04:14 PM
seiplentz's Avatar
Car: 85 Z28
Its way louder then before. And I have a ton more power. I didn't realize how restrictive my old exhaust was. Here are a few clips.
Flowmaster before
Pypes after
Old Apr 2, 2015 | 07:02 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Do you happen to have a picture of the y-pipe installed , I'm having a issue lining up the passenger side and wanna make sure I have the pipes in the right spot before I hit it with a hammer.
Old Apr 3, 2015 | 10:43 AM
seiplentz's Avatar
Car: 85 Z28
Sure here are a few more. I had a hard time lining all the piped up together as well.
Old Apr 3, 2015 | 12:25 PM
///DAN///'s Avatar
Engine: 355 SBC
Thanks a lot that's exactly what I was looking for . I'm probably gonna have to message the passenger pipe a little to clear the umi crossmember I have .
Old Apr 3, 2015 | 03:39 PM
seiplentz's Avatar
Car: 85 Z28
I was wondering if they fit that crossmember.. Post a pic of it when your done and what you had to do.
Old Apr 3, 2015 | 03:47 PM
///DAN///'s Avatar
Engine: 355 SBC
Gotta take it to an exhaust shop , I'll take some pics when it's done .
Old Apr 3, 2015 | 07:31 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Old Apr 6, 2015 | 06:03 PM
///DAN///'s Avatar
Engine: 355 SBC
Exhaust guy said he can make the y pipe work but the collector tube is touching the trans 😢
Old Apr 7, 2015 | 12:39 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Looking at those pics I can see why they are a cheap knock off. The SW Hawks one fit with no clearancing at all. Plus that outlet near the framerail is actually pointing the wrong way. The hawks ones follow the framerail perfectly.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
italiano67
Dec 11, 2016 09:21 AM
Wesly_66
Aug 26, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
