Exhaust and subframe connectors
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi
How are you doing to make room for the exhaust when you have subframe connectors Installed?
Have a 1989 TTA
Have a 1989 TTA
Re: Exhaust and subframe connectors
I have the UMI subframe connectors
http://umiperformance.com/catalog/in...roducts_id=127
No problems with the catback. The Y pipe was fine when I use 2." inch piping but when I went to 3" I had to cut and angle it a bit down by the brace to get it to fit.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The Spohn connectors give factory-like clearance to the y-pipe, which is where 90% of the problem is with subframes.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
I have the Competition Engineering#247-3111
Subframe Connectors
1982-92
And its written that they dont fit facory exhaust😫
Think i just have to start to cut into the subframe
Didn t notice that when i bougth them.
Subframe Connectors
1982-92
Engine: 383 HSR TPI
Axle/Gears: 4.10
Well thats not going to happend,i dont think you cant buy those in sweden and shipping is very expensive.
I going to modify the one i have on the car and hope they still do some good,car make close to 600fwhp so think i need them
Engine: 383 HSR TPI
Axle/Gears: 4.10
I vill not cut on subframe just going to flat out a pice of 4 inch on the connectors,they are already bolted to the car and fits fine exept for exhaust clerence
