Anyone with SLP headers and SSM SFC's inside
Old Dec 18, 2001 | 04:17 PM
Chet's Avatar
Car: GTA
Thinking about getting some coated SLP headers but I wanna know how much of a clearance problem there is between the Y-pipe and passenger side connector. What did you do to get them to clear the SFC's. Thanks
Old Dec 19, 2001 | 12:51 PM
z28dan's Avatar
Yes you are going to have problems. I have heard of people wraping the y-pipe with header wrap to stop the vibration. Your best bet out be to notch the SFC. I have a set of SSM connecters and SLP y-pipe, I never installed the SFC but I did do a mockup. It was really close and would most likely hit. I am still going to try it as soon a I find a place the will let me use there lift. Sounds like you already have your connecters on, but I know a few people that welded their connectors on when the car was being supported by jack stands. That a sure was to keep you subframe twisted.
Old Dec 19, 2001 | 01:25 PM
Chet's Avatar
Car: GTA
Yes mine are already installed. I was hoping I wouldn't have to 'notch' the SFC but the header rap is a good idea I might try that.
Old Dec 19, 2001 | 02:38 PM
Jza's Avatar
Jza
Mine has about a half inch clearance between the y-pipe and SFC, and only rattles if I gun it in reverse for some reason.
Old Dec 26, 2001 | 07:10 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Spohn makes SFC's specially designed for the SLP Y-Pipe!
Old Dec 27, 2001 | 01:08 AM
Jza's Avatar
Jza
He already has subframe connecters installed, Einstein.
Old Nov 16, 2005 | 05:52 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
back from the dead.
I mocked mine up and it looks like I have to cut off about a 6x2" section of the SFC to clear. the y-pipe hits it in every possible spot..
Anyone?
-- Joe
Old Nov 18, 2005 | 04:34 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i Have SSM SFC and SLP header installed with no problems
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
luvofjah
Sep 10, 2015 10:41 AM
hdis2002
Sep 8, 2015 02:52 PM
89fast5oh
Sep 8, 2015 09:55 AM
