Putting emmisions back need help
Car: 1987 irocz28
Engine: 305 tpi
Transmission: t5 5 speed
Axle/Gears: GU4 3.08 g80
I bought a new smog pump I put everything back on just have a problem with the pump. I dont know what connects to the back of the pump to attach the hose to the sensors that separate the flow into 2 hoses. I found a part on summit but not sure if it is what i need here is the link to the part.
http://www.summitracing.com/parts/mrg-2079
And here is the back of the smog pump.
http://www.partsgeek.com/gbproducts/...jHEaAhPb8P8HAQ
Need help have until friday to get this thing through emissions.
Re: Putting emmisions back need help
That should do the trick.
Might need to find a molded hose to go with it; unlikely that you'll be able to just jam a piece of straight hose in there, and it work. Usually you can sweet-talk the counter people at AZ or wherever, into letting you go back to the hose rack and just pick one out that looks like it'll work.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 1987 irocz28
Engine: 305 tpi
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 GTA
Engine: 5.7 TPI
Depends on the jerk at the garage. One garage I go to says they still run emissions on vehicles all the way back to the 70's. Most others perform a 'visual' only and gas cap. No tailpipe.
That's like saying that how fast your car is, depends on the spank-off talking to you at the McDonalds parking lot on Fri night.
The law is the law. Each state has its own inspection procedures (or not), specified in its laws. Look em up and bypass the other.
Car: 89 GTA
Engine: 5.7 TPI
Not really...
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Sorry... In my county of Pennsylvania vehicles 90 and below no longer get tail pipe inspection. Visual only and gas cap. I take my car to the same shop every year and never have I been required to have an emission test. Hell I have been to four different garages all official inspection stations and only one says they still preform the emissions test on vehicles 90 and below. So yeah... Sure he may still have the equipment to do it, but the state law doesn't require it hence the guy is just being a jerk and charging people for a test they don't require.
We have very strong hot-rod, and antique legislation as well.
Hopefully that won't change in my lifetime.
-- Joe
Car: 1987 irocz28
Engine: 305 tpi
These cars use to be exempt but they changed it last year now it has to be tested. 82 and up does the full monty 76 to 82 does idle 76 and older gas cap.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1991 GTA
Engine: LB9
In Utah, anything newer than '67 up to OBDII has to pass a sniffer emissions test.
We do have "Vintage Vehicle" registration, but technically it is not for your daily driver, and the vehicle has to be at least 30 years old.
I play the emissions dance each year with my '87 3/4 Ton daily driver.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yep, it varies state to state.
I gave up in Massachusetts a decade ago and moved to nh. Live free or die!
-- Joe
Axle/Gears: 10 Bolt 2.73 Open
Anyone can go to this SEMA site and register to receive their SEMA SAN Alert emails. They will help you keep an eye on anti-hobby legislation, provide you with contact info. for you legislators, the whole 9 yards. It's good stuff.
http://pages.message.sema.org/san-signup/
Car: 1987 irocz28
Engine: 305 tpi
db057
Aug 11, 2015 10:11 PM
