Y pipe with 7 quart oil pan issue....
Old Dec 8, 2015 | 05:19 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
I have a 92 Camaro, was originally a 305....Tpi... Took it out and put in a 4 bolt main, 350 carbed.
While the engine was out and being built.... I said screw it let me put in a summit extended oil pain to hold 2 more quarts of oil, didn't seem like it would be a issue...
Unfortuently the Y pipe doesn't even come close to going around this thing.
My questions are...
1.) do they make a Y Pipe to accommodate this problem?
2.) should I bring it to a gauge and build a exhaust? ( don't feel like dropping $1000 bucks....)
3.) should I lift my engine up and take this pan out and out the factory back on? ( pain in the ***........ And I don't think I can do it because it has a extended oil pickup so I don't think there is enough space to wiggle it out anyways.
Suggestions?
Old Dec 8, 2015 | 05:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Y pipe with 7 quart oil pan issue....
Pull the pan.
Old Dec 8, 2015 | 05:41 PM
defaria27's Avatar
Originally Posted by TTOP350
Pull the pan.
Problem is ... The original pan is much smaller, with a normal pickup.
I think with the extended oil pick up I won't be able to move it around like a stock pan... So I cant like twist it off.
I don't really want to pull the engine....
Old Dec 8, 2015 | 06:07 PM
Pull the pan. Put one that fits back on.
Posting on the Internet about "it's hard" "I don' wanna" won't help. The parts aren't listening.
Old Dec 9, 2015 | 09:12 AM
defaria27's Avatar
http://m.ebay.com/itm/82-83-84-85-86-87-88-89-90-91-92-Camaro-SBC-Full-Length-OBX-Exhaust-Header-/171995162693?nav=SEARCH
Would something like that work? Then get a piece to go from that my piece to my flow master muffler? Any experience with these pipes?
Old Dec 9, 2015 | 01:09 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I had the same issue with my build. The Edelbroc headers and y pipe wouldn't fit. I ended up running some Hooker shorty headers and custom head pipes past the trans. I've seen some builds with y pipes routed over to the stock cat location. Either way it's going to be custom. It really depends on what you want overall. In my case I needed a non-stock pan anyway to accommodate the 400 stroker crank and rods but with a 350 you are probably ok with the stock pan. bummer though.
Old Dec 9, 2015 | 02:43 PM
TTOP350's Avatar
Whats wrong with a stock pan and pickup? (other than no baffles/trap doors or windage screen)
The stock sbc oiling system works surprisingly well. (this isn't a mopar or ford clevland)
You could run a oil filter relocation with 2 large filters, increase capacity and keep the extra oil out of the pan.
You could get the correct pan for the car with around 6quart capacity.
Old Dec 9, 2015 | 05:51 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Defaria, I think you're right about pulling the pan with the engine in the car. I just barely got my stock oil pan out with the engine in the car and had to loosen a motor mount if I remember correctly. I seriously doubt I could bet my Moroso oil pan out with the engine installed. I wouldn't even try. Your options are;
Pull engine and swap pans.
Replace cross pipe with custom.
Install different type header/manifold with different type exhaust.
Run open headers.
Honestly I would just make or have a different cross over pipe made. You may lose a little ground clearance but that's about your only option with the motor in place. You can always pull it later if that doesn't work out.
John1987formula
Apr 13, 2020 09:58 PM
matt0626
May 4, 2016 11:55 PM
Sentinal91
Camaros Wanted
Jan 28, 2016 10:56 PM
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
Slash
Nov 17, 2015 11:54 AM
