locking header bolts?
Subscribe
Jul 10, 2016 | 01:37 PM
Hey guys, I have a set of hooker shorty headers (don't think they're competition headers). I feel like every 20 hours of running I have to tighten the header bolts. I was wondering if you guys had a recommendation on locking header bolts.
I saw vibe-lock bolts but I have no idea how they'd work. Eventually I want to ditch the shorty headers and go with long tubes but that'll be once I get my money's worth out of these.
I saw stage 8 but they look pretty difficult to get to some of them. So basically something like the vibe locks but I have no clue how those would work.
Btw, I did search locking header bolts, however when I did (on my phone) it didn't produce any results, maybe the app is just wierd lol
Reply 0
Jul 10, 2016 | 01:53 PM
Re: locking header bolts?
I use studs and "nord lock washers"
Reply 0
Jul 10, 2016 | 03:51 PM
I had 2 lock bolts on the same port come loose...with the locks properly on them.
Reply 0
Jul 10, 2016 | 08:05 PM
Do you guys know how the vibe-lock bolts are supposed to work?
Reply 0
Jul 11, 2016 | 03:49 AM
Quote: Do you guys know how the vibe-lock bolts are supposed to work?
http://www.grumpysperformance.com/safe4.JPG
Reply 0
Jul 11, 2016 | 09:29 AM
I was looking at Piercys vibe-lock bolts. They have just a small wire to an attached star wheel but im not sure if they have clearance on hooker headers.
But what I'm getting so far is you guys aren't much of fans of locking header bolts?
Reply 0
Jul 11, 2016 | 09:39 AM
a dab of red rtv
Reply 0
Jul 11, 2016 | 09:42 PM
I use the Mr. Gasket ones. They have a serrated flange that grabs into the gasket and I also am using a Percy's multi layer aluminum exhaust gasket. About 35-40 lbs. of torque is needed. Got them from Jegs
Reply 0
Jul 12, 2016 | 01:43 PM
Quote: I was looking at Piercys vibe-lock bolts. They have just a small wire to an attached star wheel but im not sure if they have clearance on hooker headers.
My lock bolts are ok. Its just 2 on the same port came loose some how, once.
Reply 0
Jul 12, 2016 | 09:35 PM
If you want to replace them with a lock wire type of bolt, it's best to get lockwire pliers and practice on something prior. There's a little bit of an art to it. Did you check your threads in the bolt hole, is there any sign of the threads weakening?
Reply 0
Subscribe
