Where is a cut-out supposed to be placed?
Old Jan 2, 2002 | 01:30 AM
JR4444's Avatar
Do you weld the cut off before or after the cat? I don't belive it would be illegal to put it in front of the cat, because it's for "off road use only" but I'm not sure. The only problem I might see with having it before the cat is a lack of back-pressure. Let me know what you think, thanks
Old Jan 2, 2002 | 03:30 AM
Jza's Avatar
Jza
You can put it wherever you want to. Personally, I put mine after the cat for three reasons:
1) It cuts down on the noxious fumes that drift into your car from having the exhaust exit underneath. That stuff makes me feel nauseous after a bit.
2) There's a very convienient place under the passenger side rear seat that accomodates the cutout on the intermediate pipe.
3) Easier to reach (since mine has wingnuts) than if it were before the cat (have to reach around the front wheel) or at the headers (have to jack up the car).
And as far as "legality" they don't look at "where" the bypass is. If you bypass or have a method to bypass an operational muffling system, it's illegal. I forget which state that was that I read that about... But here and a lot of places don't exactly check that kind of thing.
Old Jan 2, 2002 | 06:18 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What he said....
Old Jan 3, 2002 | 08:43 PM
91WS6TA's Avatar
you might want to check out with emisions inspection station, here in Tucson every time i go in yearly, they walk all the way around with the mirror. That would suck to have to take it out to pass the test yearly.
Old Jan 3, 2002 | 09:25 PM
JR4444's Avatar
I live in Tucson too.....good thing I got my emissions done last month.
Old Jan 3, 2002 | 09:51 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If u have headers, right after the headers.
Old Jan 4, 2002 | 11:42 AM
ATOMonkey's Avatar
That's where mine are. I got a pair of cable operated ones from JC Whitney. I just got them done, so I'm waiting until spring to see how bad they're going to leak. I think that I'm going to weld a flange onto them so I can cap them properly and then take the caps off during the weekend.
Since I have Hedman shorties I put them in the Y pipe for simplicity.
The long term plan is to run some short pipes off of the cutouts for some flame throwing fun.
Old Jan 4, 2002 | 12:17 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Here's mine(on my Z28)If I put on e on the 'Bird it will be in the same location.
Old Jan 4, 2002 | 02:13 PM
JR4444's Avatar
I found a JC Whitney cutout, that my friend had and it's the pull kind. Can I only use one at the end part of the Y-pipe or do I have to buy 2? I have a stock Y-Pipe right now.
Old Jan 9, 2002 | 03:00 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Now, at the beginning of this post where it was said about the "lack of back pressure". Is that bad? Cause I just ordered one from Summit Racing and I was gonna put on b4 the cat. But, not sure what backpressure is or needed for. It gives you more HP that way doesn't it? I just don't wanna hurt my car.
Old Jan 9, 2002 | 03:57 PM
JR4444's Avatar
Low backpressure can cause valve float. Everybody has their own opinion on if this causes problems or not. I've heard of people running open headers for months w/o problems. And I've heard people say a cut-out can cause problems if opend for too long, I don't really know what the truth is
Old Jan 9, 2002 | 05:10 PM
breathment's Avatar
i didn't know backpressure had anything to do with that. Im not saying your wrong, i just havent heard of that. However i still think you would have to be running at VERY high RPMS for that to happen anyways.
Old Jan 9, 2002 | 09:03 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I've been told so many different things about this so if I get it backwards again, lemme know. Low backpressure = more torque Backpressure (from cat and cat-back) = more horsepower. Hopefully I didn't screw it up again, but what are you gonna do on 2 hours of sleep?
Old Jan 9, 2002 | 09:06 PM
breathment's Avatar
more back pressure = more low end torque, to an extent anyways..
just keep repeating it
i know how u feel
Old Jan 9, 2002 | 09:51 PM
vortech305's Avatar
hey HM Murdock after u placed that cutout in that area of the exhaust how was the sound, was it the same, Was it a throaty or import sounding grunt?
Old Jan 10, 2002 | 06:05 AM
Jza's Avatar
Jza
I doubt you'd think it was import sounding..lol.
Old Jan 10, 2002 | 08:37 AM
vortech305's Avatar
ud be suprised i've seen muscle cars withe open headers and sound like a 5 inch fartpipe on a honda.
Old Jan 12, 2002 | 04:55 PM
f-bodlover04's Avatar
i think this sounds about right , also with limited backpressure , you only want to operate in higher temps , because cold air will shock cool the headers and block , this = very bad , am i right about this
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
