Mid length header Install
Old Jun 21, 2018 | 01:07 AM
Go Blue's Avatar
hey all! Im about to install my new mid length Hedman Headers and when I took off the old manifolds there were 2 mounting bars (1 on each side) that attached to studs that were on the exhaust manifolds. 1 came from the back bottom side of the power steering pump and the other came from the back bottom side of where the smog pump used to be. My question is, do I need to still mount these when I install the headers? Im assuming theyre for strength and rigidity for the power steering pump and the no longer there smog pump?? Im just checking as I bought ARP header bolts since the old studs and bolts are all rusty. Thanks in advance!!
Old Jun 26, 2018 | 06:00 AM
Go Blue's Avatar
Re: Mid length header Install
Anybody?? I'm just asking as I bought ARP header bolts and none of them are studs, so i'd have to get 2 studs for the front bolt on each side and i'd like to start installing the headers tomorrow if possible.
Old Jun 26, 2018 | 07:57 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would re use all factory brackets. Grab a couple studs or long bolts. That is what I did for my accessory brackets.
Old Jun 29, 2018 | 10:53 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
usually they give u hardware for it def put the braces back so you don't end up with a problem else where
Old Jun 30, 2018 | 11:57 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
you definitely want to use the brackets as they stiffen the front end accessory brackets. you may need to make some spacers to the header flange to have them properly spaced out... i had to do the same using my mid length headers on my zz5 crate install
Old Jul 7, 2018 | 07:29 PM
iosigma's Avatar
Car: 2017 Jeep Cherokee
Transmission: 6 Speed, 5 Speed T-5
I started installing them today. Was just able to get the driver side was terrible to get in. Wouldnt clear the steering shaft or the tab on the bottom block. Had to grind down the tab and ended up having to put a dent in the rear collector before it would fit. Im dreading the passenger side tomorrow:-/
Old Jul 7, 2018 | 07:32 PM
Go Blue's Avatar
If you get the coolant pipe unbolted and lift the engine 1-2 inches they almost fall right in. Im having problems with my engine mount and the previous owner of the headers put the oxygen sensor hole facing right at the block. I also have to re-route some new brake and fuel lines but its getting there.
Old Jul 7, 2018 | 08:42 PM
iosigma's Avatar
do you have to lift the engine? I can get all the coolant pipes out of the way because Im installing all new air conditioning. So all of that will be gone
Old Jul 7, 2018 | 10:25 PM
Go Blue's Avatar
I have my ac completely out and still couldnt get it in completely without lifting the engine. I just used a floor jack with a piece of wood and lifted it by the oil pan. Not really how I wanted to do it and now I cant get the nut on the bolt on the drivers side engine mount. But the headers pretty much slid in after I lifted it. I didnt have to grind anything so far.
Old Jul 8, 2018 | 05:13 AM
iosigma's Avatar
Did you unbolt both sides of the engine or would it pivot to the driver side
Old Jul 8, 2018 | 08:14 AM
Go Blue's Avatar
I originally unbolted both sides per Headmans instructions. Now, since the passenger side is in, Ive only been unbolting the drivers side to move the brake lines away from the headers. After I put the headers on, I havent figured out how to get my big hands in there to either put the nut or bolt on the backside of the engine mount. Otherwise, everything else went well.
Old Jul 8, 2018 | 10:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Telescoping magnet maybe
Old Jul 8, 2018 | 11:12 AM
Go Blue's Avatar
The problem is its pretty much a blind place where the bolt either goes in or comes out. I cant see the hole on the backside of the mount and I think the bolt is too long to go in that way and I doubt I can get a wrench on it. I tried a few times yesterday but no luck getting the bolt in that way.
Old Jul 9, 2018 | 06:32 PM
iosigma's Avatar
Ended up not having to unbolt the engine at all. The passenger side went in no problem. Forgot to zip tie the engine temperature sensing wire up and so that burnt through on the test drive, but other than that I'm very pleased
Old Jul 10, 2018 | 10:08 AM
Go Blue's Avatar
I have to at least loosen my driver's side header back up because where the previous owner welded in the O2 sensor bung isn't going to work and I still need to tidy up some brake and fuel lines that are just too close to the headers for me to feel comfortable. Maybe I can figure out how to get it in without lifting the engine again but it's so tight in there that I couldn't wiggle it enough to make it work last time. Glad you were able to get yours in easier than me.
Old Jul 12, 2018 | 07:39 AM
Go Blue's Avatar
I figured out how to get the driver's side header out without lifting the engine. I had to take off the valve cover and disconnect the steering column, but it came out and I was able to put the engine mount bolt back in. I had to take it back out to fix the brake lines and get the coolant temp sensor and O2 sensor connectors out so that they could be better routed anyways. I had to order a plug for the O2 sensor bung since it was put in a spot where there's no possible way to put the O2 sensor in. I can't wait to hear the difference between stock exhaust and the 3" cat back with headers and no cat!
badidea
May 22, 2019 09:13 PM
Fastime
Sep 27, 2016 03:20 PM
GFusick
Feb 17, 2016 11:37 PM
anesthes
Jun 6, 2012 08:45 AM
406bird
Dec 22, 2005 05:43 AM
