Question about eBay long tube headers
Old Jan 26, 2020 | 03:10 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88 gta trans am had a t5 now it's a lt1 t56
and the ebay ad only says at
I asked them and they only said at I think I'm talking to a kid
they have chrome headers long tubes and ypipe
has anyone ever installed them on my car before
any reviews
ty
Old Jan 26, 2020 | 08:50 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Question about eBay long tube headers
I had these headers to use with a modified T5 Bell housing and then purchased a T56. In my ever changing scheme I sold the headers but was planning to bolt the two together and check the fit before I sold them and I didn’t. Wishing I had and hopefully someone here can verify for you.
Old Jan 26, 2020 | 09:09 PM
bensbaby's Avatar
Engine: 383 built
what was modified on your t5 bellhoising?
Old Jan 27, 2020 | 10:09 AM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
I made them fit around my LT1 T56 with some heat and a hammer.
Old Jan 27, 2020 | 02:02 PM
CKone's Avatar
After reading a few related threads the plan was to remove the slave cylinder fork and mounting ear from the bell housing and switch to a Hydraulic TOB to make room for the header to pass through on the drivers side. Thought I had also read somewhere that these headers fit with the T56 setup but I have no proof to backup those claims. They looks almost similar to me so I think the same problem would persist with either trans
Old Jan 27, 2020 | 05:21 PM
TORN's Avatar
Car: 88 IROC-Z
I cut off the neck down to 2.5 and tig welded on 3 inch extensions. It bolted right up to the Hooker Blackhawk dual exhaust.
Old Jan 27, 2020 | 08:55 PM
bensbaby's Avatar
Engine: 383 built
I only have a y pipe and a 3inch factory performance exhaust
but you didn't use the y pipe
I have flow tec shortys now with a flowteck y pipe and it's so close to hitting the oil pan
does anyone have any for sure idea with lt1 t56 ??
ty tho
Old Feb 18, 2020 | 02:45 PM
RoadRace's Avatar
Car: 85 IROC
Engine: 5.7
Axle/Gears: 4.11 torsen, 4th gen rear
This is the same as my car so this is good news. can you confirm they are 1 3/4" primary tubes?
did you have to remove anything during installation (other than jacking the motor up)? if you have a pic of where you have make clearance, that would be super awesome!
matt
Dan Baker
Jul 13, 2019 06:53 PM
Stuman
Jul 27, 2018 09:47 PM
IROC-Turbo
Oct 29, 2017 11:58 PM
bigcheeseburger
May 10, 2015 09:44 AM
scott13676
Dec 1, 2014 09:19 PM
