Cat replacement
Old Apr 1, 2020 | 02:12 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Cat replacement
Hey y'all -
So..my cat has been rotted for a while - at least the heat shield. Finally gonna replace the damn thing. Ordered a new OE fit. Any tips/tricks I should be aware of? V8, auto trans if that helps w/mounting hardware, etc. Not sure what comes with the cat. I ordered the air tube kit as well to go with it. Will I need to source bolts, gaskets, etc? Any help is appreciated. Not really one for exhaust work.
Old Apr 1, 2020 | 08:04 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Re: Cat replacement
30 views no replies. No tips. Tricks. Things to look for. nothing. Cool...y'all stay safe in corona land.
Old Apr 1, 2020 | 08:29 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Cat replacement
Very good chance that everyone who clicked on this thread has no experience with your specific question and therefore cannot offer any kind of advice. Case in point, I clicked on this thread and have zero experience with replacement converters.
Old Apr 1, 2020 | 09:03 PM
Drew's Avatar
Re: Cat replacement
It's a catalytic converter. Basic exhaust plumbing. Remove the old one, install the new one. Who knows exactly what you might run into, but it should be very straight forward.
Old Apr 1, 2020 | 10:38 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Cat replacement
No experience. But it will be interesting to see just how good that OE fit is. I hope it's prefect, but I have my reservations...
Old Apr 2, 2020 | 12:10 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Cat replacement
Soak the nuts/bolts with a good rust desolver. I like PB Blaster (Walmart and other stores). Let the solvent soak for hours, or longer, depending on how bad the rust appears. Make sure the car is not running too rich, as this will ruin a Cat. If it uses gaskets, get new ones.
Old Apr 2, 2020 | 10:34 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Re: Cat replacement
New Stainless Bolts, nuts, and washers to make it easier next time..
Old Apr 2, 2020 | 12:07 PM
Drew's Avatar
Re: Cat replacement
Stainless hardware of the hardware store variety will just be cheap low quality trash that will gall and seize anyway. At least with cheap steel you have a fighting chance of getting it apart without destroying it.
Old Apr 2, 2020 | 01:55 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Re: Cat replacement
Anyone happen to know if it needs gaskets? I checked a few diff sites and none were recommended which i find kinda strange.
Old Apr 2, 2020 | 03:38 PM
Drew's Avatar
Re: Cat replacement
Was the car built prior to 1986? If not, it's a slip fit on one end and a ball flange/socket arrangement on the other, no gaskets.
Old Apr 2, 2020 | 08:32 PM
NoEmissions84TA's Avatar
Re: Cat replacement
And hi-temp anti-seize. Stainless on stainless will gall.
Old Apr 2, 2020 | 09:47 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Cat replacement
New grade 5 or 8, ferrous bolts and anti seize, stainless is overkill. IMO.
Old Apr 2, 2020 | 10:08 PM
Drew's Avatar
Re: Cat replacement
Old Apr 3, 2020 | 09:10 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Re: Cat replacement
Sweet thanks. Hopefully I can tackle this on my own then..it's a 91.
Old Apr 3, 2020 | 11:18 AM
Drew's Avatar
Re: Cat replacement
You'll probably need to cut the old cat off the Y-pipe where it was clamped, or heat it red hot with a torch, since the clamp will usually have crimped the tubes together.
Old Jun 2, 2020 | 03:11 PM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
Re: Cat replacement
You speak the truth! But you need to sing "Tin Man" by America, while trying to remove it from your fingers.
BlueWrath92
Jul 8, 2012 11:27 AM
IROC216
Jan 28, 2009 10:32 PM
Slow2.8
Mid-Atlantic Region
Jun 21, 2006 04:04 PM
xpimpitox
Feb 17, 2003 11:56 AM
