Product to dampen vibrations from cat rubbing on subframe connectors?
Old Apr 22, 2020 | 12:30 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I installed Spohn Subframe connectors on my car in 2014 when it still had the original 305 exhaust setup. When I swapped in the 350 in 2016 I stepped up to DynoDon headers with his Y-Pipe and a 3 inch catback exhaust. Since the swap increased the pipe diameter, the top of my catalytic converter rubs the cross brace to the frame on the subframe connector. This causes vibration in the cab at certain RPMS (especially around 1800) when it rubs on that cross brace and is rather annoying. I'd rather not have to get the brace relocated if I can avoid it, so I'm wondering if there is some sort of heat resistant product that I could wrap around the brace to dampen the vibrations. Or any other ideas that you all would have.
Old Apr 22, 2020 | 07:55 AM
Re: Product to dampen vibrations from cat rubbing on subframe connectors?
Never seen, heard of, or even imagined, any material that could accomplish that. Not a viable "plan".
Adjust the exhaust position.
Find a smaller diameter cat.
Old Apr 22, 2020 | 08:08 AM
BIRD91ZRAG's Avatar
Adjust the pipe with a hammer. Won't hurt a thing.
Old Apr 22, 2020 | 08:16 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
This outa do it
https://www.harborfreight.com/4-lb-h...mer-69240.html
Old Apr 22, 2020 | 08:39 AM
Drew's Avatar
Sometimes the common sense answers like ones given in this thread bring a tear to my eye.
Old Apr 22, 2020 | 10:44 AM
Car: 1991 Z28
I always like to explore all of my options before going with a permanent solution. I'll go out today and see what I can do after work.
Old Apr 22, 2020 | 10:57 AM
Drew's Avatar
The stock dual cat setup in my Formula rubbed my Alstons initially. After shifting things around a bit I was able to make enough clearance that the clunking went away. There's a ton of adjustment in the transmission crossmember and the exhaust. Should be able to shift the exhaust down, or the transmission over a hair to give a bit of clearance. Otherwise, pop a relief dent in the exhaust pipe like the big flat spot above the panhard bar in back.
Old Apr 29, 2020 | 12:47 AM
Car: 1991 Z28
Just to follow up: I went out last week and after some effort was able to reposition the exhaust. Its 95% better now with only a tiny rattle at times. I'll take it!
Firebird sweden
Mar 10, 2015 03:20 PM
mswen22780
Jun 7, 2012 03:36 PM
88fastgta
Sep 10, 2009 05:50 PM
Hawk92z-TDZ
43
Mar 16, 2003 03:14 PM
jarek5_7
Jul 5, 2002 10:28 PM
