Going from 2.5 to 3.0 exhaust make any difference?
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
L31 crate 350 with stock TPI induction and Hooker shorties/y-pipe. The y-pipe is the standard Hooker cat-delete version that reduces to 2-1/2 outlet. Currently runs to a Dynomax 2-1/2 catback. Got a great deal on a Magnaflow 3-inch catback but now wondering if it's worth all the trouble to expand the y-pipe to 3 inches and figure out how to mate it with the Magnaflow. Will I really gain much of anything with a stock longblock L31 and stock TPI induction?
Re: Going from 2.5 to 3.0 exhaust make any difference?
Yes I think you will, on that motor. Definitely worthwhile.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yes do it, when I bough my TA it had a 350 with some crappy 882 heads and terrible summit headers and it still gained going from 2.5 to 3"
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Definitely something you should do. A good exhaust can free up as much as 30hp over factory set up depending on your mods.
Engine: L31 350 TPI
Thanks, appreciate the input. Unfortunately, the y-pipe is really a problem. Can't find anyone local that can/will modify output to 3-inch. They all want me to bring the car to them so they can modify it on the car. Won't modify off the car because they've had too many people complain about their parts not fitting. Problem with this is I can't install the Magnaflow before the y-pipe is modified. But I can't get the y-pipe modified without the Magnaflow installed. Catch 22. REALLY wish I would have gone with a different header/y-pipe combo, but it was for the 305 and figured that would be fine. I really didn't expect to do a 350 swap in this car.
If the exhaust you want to put on is slip-fit, sounds like something you can do yourself in the driveway. No need for "shop".
Rent a chop saw and a wire welder at the rental yard if you need it. Chop the bottleneck off, weld on a piece of 3" pipe, install exhaust, done.
