Heat riser gasket?
Re: Heat riser gasket?
There were no gaskets on any of that from the factory.
Between the manifold and the valve, if you look around in the exhaust gasket aisle behind the counter at your local corner parts store, you'll be able to find one that fits, if you just REALLY want to put something in there that's guaranteed to fail. Between the Y-pipe and the valve, you just gotta clean up the surfaces with sanding or grinding or whatever.
Car: 1985 Z28
As mentioned, there isn't supposed to be a gasket here. But if you need one, Walker part # 31307 is a good fit for the HO/TPI manifolds and I believe it would work for the other manifolds too.
