another third gen with true dual 2.5 "exhaust
Old Oct 18, 2020 | 12:12 PM
teamnegrillo's Avatar
Car: camaro iroc z 1990
Engine: 350 tpi
Transmission: auto
Hi everyone
I remind you again that I am Spanish and I use the google translator, forgive me if there is something that is not well understood.
The other day I made a post about the installation of the headers, because I also took the opportunity to make a true dual 2.5 "exhaust, of course I have used to cancel the catalysts, put a new xpipe and mufflers.
the change in performance and sound has been brutal and also achieved more free height with the floor.
I have done the new route following the original route, as some users of this forum have done in their cars (thanks for your ideas)
I put some photos of how they are.
I have also taken the opportunity to protect the oil pan from the heat, in this picture you can see
I know that welds are ugly, but understand that I am not a welder and they need to be cleaned with acid stripper
The lowest point of our exhaust has always been the area of the cat, with the new route and achieved that it is not like that, in this photo you can see how the apanas tubes protrude from the chassis.
I have made the two rear outputs of 3 "because in 2.5" they looked small and also I have cut them at an angle
well, that's all for now, when I can do soundchecks and put them here.
greetings to all
Old Oct 18, 2020 | 01:36 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: another third gen with true dual 2.5 "exhaust
Very nice work, I like it!! 👍🏻
Old Oct 18, 2020 | 09:13 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Nice job. One of the better dual exhaust installs I have seen. I bet its pretty loud with those mufflers and no cats.
Old Oct 19, 2020 | 04:29 PM
83 Crossfire TA's Avatar
What kind of acid stripper? Unless the pipe is stainless and the weld filler is a higher grade of stainless the welds will rust. If they already had a coat of rust on them a phosphoric acid treatment might help, but otherwise giving them a coat of most any acid will make them weaker. Give them a coat of high temp paint, spray galvanizing or something similar and leave them alone.
When I was younger I thought that all my f-bodies needed dual exhaust sticking out under the bumper, and my '83 (I put an exhaust on that in 1991) had dual 3" pipes like yours. I finally decided that didn't quite look right and I tried all sorts of different combinations, even trying something low profile like 4th gen exhaust tips, and was never quite happy. I finally decided that there were only 2 ways to go: either put cut outs in the factory bumper like most modern cars have (somewhat difficult because that will involve cutting the steel supports and part of the steel body) or just tuck turndowns back behind the bumper like the factory did. My current 3rd gen has a single 3" turn down tucked up on the driver's side which you can't see, and a second turndown going to an electronic cutout on the passenger side, again, which you can't see. I'm finally happy with what my exhaust looks like
BTW, nice setup, I feel like that's the only good way to do a dual exhaust on these cars.
Old Oct 19, 2020 | 08:01 PM
NoEmissions84TA's Avatar
Has anybody ever tried oval tubing? I know, the price would probably be ridiculous.
Old Oct 20, 2020 | 08:26 AM
Engine: 350 tpi
Transmission: auto
This is what I use to clean the welds and tubes
Old Oct 20, 2020 | 08:28 AM
Engine: 350 tpi
Transmission: auto
I thought about it, but they don't sell them here
Old Oct 21, 2020 | 07:09 AM
Abubaca's Avatar
Very nice work! Looks good!
Old Oct 21, 2020 | 07:36 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Fine work! Looks great and bet it sounds killer!
Old Oct 30, 2020 | 10:02 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
hey aside from the welds looks great and its well designed
(I'm not a welder either)
Old Oct 30, 2020 | 09:31 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have oval on mine.
3" collectors to oval pipes, then to a single 4" round pipe over the axle to the 4" muffler and single 4" exit
The oval pipes help with clearance for sure.
Yes, they are more expensive.
Search my name to see my exhaust system
Old Oct 30, 2020 | 11:58 PM
Outkast Actual's Avatar
Car: 1988 Camaro RS
Engine: 383 Stroker
Transmission: TH400 3 Speed Auto
Axle/Gears: 373 Richmond
Outstanding work... I'm in the situation that you "were" in... my exhaust sits too low... it's dual exhaust with an X pipe. I'm hoping that I can find someone local that can re-route my exhaust so that it sits up closer to the body.
Old Oct 31, 2020 | 12:44 PM
Car: 1988 Camaro RS
Engine: 383 Stroker
I would also like to remind folks that I'm a mechanical idiot and the following question isn't an attack of the fact that the OP is Spanish and using Google Translator... I'm just really ignorant when it comes to auto mechanics...
The question I have is... what is apanas tubes?
I searched that term & even searched "Gen 3 Camaro apanas tubes" and couldn't find anything. I'm not sure if the term is misspelled, an error in translation, or just something that I can't find in my searches. I even tried Google Translate... lol.
Old Oct 31, 2020 | 04:09 PM
Engine: 350 tpi
Transmission: auto
The lowest point of our exhaust has always been the area of the cat, with the new route and achieved that it is not like that, in this photo you can see how the barely tubes protrude from the chassis.
Old Nov 4, 2020 | 08:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Nice job good to find another member of the ugly but functional weld club
soloc4
Members Camaros
116
May 8, 2026 11:08 PM
soloc4
Apr 18, 2024 08:40 AM
DeathMetalTony
Apr 11, 2010 09:16 AM
82camaroWI
Fabrication
Dec 7, 2008 12:35 AM
Ovrclck350
Mar 28, 2001 05:20 PM
