help for Catalytic Converter
Old Feb 22, 2021 | 06:13 AM
Henry79's Avatar
Car: trans am 86
Engine: 305 stock
Transmission: stock
Greetings to all flks!
i have a 1986 lg4 trans am and want to remove the catalyst. I would like to know which one you use and where I could find it, there is no problem with the emission here in Spain it is not prohibited. thanks for the help, then I'll give you photos of the car
Old Feb 22, 2021 | 08:46 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: help for Catalytic Converter
Hello Henry79. Welcome aboard.
So you are looking for a pipe to replace the catalytic converter?
Or are you looking for a replacement converter?
Old Feb 23, 2021 | 05:44 AM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Id just put a remote cutout there for fun.
Old Feb 23, 2021 | 07:35 AM
Henry79's Avatar
Car: trans am 86
Engine: 305 stock
Transmission: stock
I am looking for a suppressor, a part that does not do the function of the catalyst or that does not limit the vehicle like the catalyst does.
Thank you
Old Feb 23, 2021 | 01:44 PM
83 Crossfire TA's Avatar
A modern, monolith style catalyst isn't a significant limitation on most reasonably powered cars, it's not more restrictive than a straight-through glass-packed muffler if even that. Yes, if you're trying to force 500hp worth of exhaust through a 2.5" converter it will be a restriction, but a 2.5" muffler will be a bigger restriction.
Old Feb 23, 2021 | 05:57 PM
Henry79's Avatar
Car: trans am 86
Engine: 305 stock
Transmission: stock
thanks but, i need the way to delete o supress the catalytic converter....you know where i can find that piece?
Old Feb 24, 2021 | 01:30 PM
Depending on the model, a piece of pipe about 2' long and between 2.25 and 2.75" OD.
Old Feb 24, 2021 | 01:32 PM
Henry79's Avatar
Car: trans am 86
Engine: 305 stock
Transmission: stock
ok, so i need where i can search the items for a 1986 trans am lg4 305 cu inches
Old Feb 24, 2021 | 06:09 PM
DynoDave43's Avatar
Henry,
In this country, you used to be able to buy a "test tube", which was designed to bolt exactly in place of the catalytic converter. But I don't believe those are available anymore. They were sold under the guise of testing, to see if the catalytic converter had plugged or otherwise failed. But more often than not they were used to illegally replace the converter on a permanent basis.
What Mark is suggesting above is that any competent exhaust shop with a pipe bender can make you that piece of pipe and weld some flanges onto it (if applicable). And that is what I would recommend as well if you want to eliminate the converter.
Old Feb 24, 2021 | 06:35 PM
Scott's 83' Z's Avatar
Car: 1983 Z28
Engine: L69
I think there might be a slight misunderstanding of terms. “Supress” is not the same as “delete”. In terms everyone here would understand your want to REMOVE the converter.
If you want to remove the converter then examine the rest of the exhaust system for corrosion. If it is in good shape then cut out the converter and weld in a piece of the same diameter pipe to replace the converter. If you don’t have access to welding equipment then locate a auto repair shop that can do the work for you. The pipe is nothing special, just aluminized steel. There probably is a air injection line you will also need to disconnect as well.
if you have corrosion issues then you should look into replacing all the rusted parts. Web based companies like Summit Racing, Jets, CARiD have products you can order. They also have modern replacement converters including 3” inlet size converters that you can purchase as well. It might be more cost effective to have a local shop that can fabricate a system make one for you rather than ship something in from the US.
Old Feb 25, 2021 | 05:46 AM
Henry79's Avatar
Car: trans am 86
Engine: 305 stock
Transmission: stock
thanks a lot, i will do it that.
3rdgenmaro
May 21, 2010 08:48 AM
blackroc68
Mar 21, 2010 10:29 PM
dvardaman85
Jan 30, 2010 09:27 AM
