Code 32 EGR replacement
My 89 IROC 5.7 is running great, except I’m getting a Code 32. Typically the issue is either the EGR solenoid or the EGR valve. The local parts stores can get the valve, but the solenoid seems to be a bit trickier. All related posts I found were outdated, mentioning it’s discontinued through GM and no replacement known. Does anyone know where I can source an aftermarket solenoid replacement? If not I’m going to swap the valve first to see if it resolves the issue. Thanks for your time 🙂
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 32 EGR replacement
Are you sure it’s not the temp switch throwing the code ?
Engine: Lb9
Transmission: M20
http://web.archive.org/web/201801251...vythunder.com/
corvette restoration parts places like zip ect has the egr temp switch.
can use a caddy egr solenoid. Or if it’s the temp switch program out the code 32
