Best Exhaust Setup for Shorty Headers?
Old Jun 16, 2023 | 01:12 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Can anyone recommend a good exhaust setup to run with shorty headers? I’ve got an 87 Trans Am with SBC, T56, and Spohn crossmember. I bought a y-pipe with my headers a long time ago. I had my brother install the y-pipe bc he’s a high school auto shop teacher and has a lift. I love my brother but, sometimes I really wonder about him bc he told me the y-pipe wouldn’t fit around the oil pan so he had to flatten the part that goes behind the pan to get it to fit. I was at work at the time and he didn’t bother to ask if he should do it. I’ve been running like that ever since. I would like to fix this issue. Thanks.
Old Jun 17, 2023 | 03:56 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: Best Exhaust Setup for Shorty Headers?
I have the OE Y pipe with pipe in place of CC. If you aren't worried about ground clearance you can go with duals. If you want some clearance follow the OE layout. Maybe use larger pipe. Paying someone to do it will not be cheap. Pics would help to see how much flattening of the pipe has been done.
Old Jun 17, 2023 | 04:07 PM
Engine: SBC 350
I’ll have to see if I can get some pics at some point. I also have straight pipe in place of CC. I guess my real question is what options other than the stock Y-pipe will work well under the car? Are there other options from the shorty headers other than the Y-pipe, since it didn’t quite fit with my oil pan? I have a Moroso deep oil pan and for some reason this caused an issue with the y-pipe not fitting between the pan and the crossmember.
Old Jun 17, 2023 | 04:14 PM
BBCSwap's Avatar
I'm sure it did. Probably your only option is custom made. Go to an exhaust shop and have it made to fit. Depending on how much the pipe is flattened you might want to leave things alone. Pics please.
MustangBeater20
Jun 16, 2014 04:55 AM
383roller
Aug 12, 2010 09:14 PM
lucky14
Sep 30, 2008 11:29 PM
92IrocRS
Feb 21, 2007 01:36 AM
Sonix
May 24, 2006 10:15 PM
