Anyone runnin Hedman LT Headers #68460?
Old Oct 4, 2006 | 03:37 PM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
I just put my hedman long tubes in last night, and I dont want to run my car on open headers cuz I dont wanna be replacing exhaust valves already. I wanted to see what you guys thought would be the best route from there on back. I have never done any exhaust fabrication, and I really hate paying a shop to fab a y or h-pipe for me.. but I cant find anyone that makes a y-pipe for hedman lt's, and the mufflex one for hookers 2210's is ridiculously expensive imo... any advice would be greatly appreciated
Old Oct 4, 2006 | 05:33 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
You will have to fabricate a y-pipe or some type of dual setup for the Hedman LT's. I've ran both a y-pipe and dual setup with those headers, it can be done but if you don't weld I'd take it to a shop. I wouldn't worry about hurting valves with open headers unless its extremly cold outside. Only problem you will have is annoying the neighbors...or getting pulled over. Heres a couple of posts by mw66nova, showing how he did his exhaust.
https://www.thirdgen.org/forums/exha...el-bent-y.html
https://www.thirdgen.org/forums/exha...aust-pics.html
Old Oct 4, 2006 | 06:16 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I used the Hedman S bends and came straight back into a set of Chambered tube mufflers, added an H pipe at the end of the S bends and installed dumps, job done.
Old Oct 5, 2006 | 11:08 PM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
working on installing the same headers on my 92, got a universal adjustable h-pipe assembly from jegs for under $40 bucks. will require some welding tho.
Old Feb 21, 2007 | 01:36 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
simple:
https://www.thirdgen.org/forums/exha...ighlight=68460
this is how im doing it on my 82 t/a this spring or sooner finally
real simple and easy
i will buy pipe locally and i already have a pair of LT's
just need to order the s curves pair and get mufflers and im ready to go
so far ive spent zero dollars cuz i got the headers for free,
the mufflers will be about 65 bucks
im getting force pro series mufflers from jegs which are a 32 dollar flowmaster
mw66nova has the best and most simple exhaust setup that ive seen so far, the Summit S-curve pieces are SO much better than playing the pipe-bending game, IMHO and are what i am using under my ride
ive opted to not go with an H-pipe though
but i may change that at a later date possibly
and will eventually change to coated headers too
good luck
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
