hooker 2460HKR
Old Jun 24, 2024 | 03:04 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
hooker 2460HKR
Hi all,
Just replaced a stock 350sbc with another 350 (+HP, alum heads, etc.). I ran into an issue with the y-pipe. I'm using the same headers, Hooker 2460HKR, with the same y-pipe, and suddenly the y-pipe won't fit. It seems the y-pipe is hitting the oil pan and ii won't 'attached' to the passenger side header for about less than 1/2 inch. Any advice? Would the flowtech y-pipe 11102YFLT solve the problem? This y-pipe comes in 2 pieces, it might be easier to adjust/manage/attach/install/etc.
Old Jun 24, 2024 | 03:12 PM
Re: hooker 2460HKR
Problem is more likely the oil pan.
Leave the exhaust alone and fix that.
Old Jun 24, 2024 | 04:06 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: hooker 2460HKR
Yup, totally agree. Get the right oil pan on. You could make a custom y pipe. Seems like the oil pan is the move but if you can fab well make/modify the y pipe. Is the pan close to anything else? The frame? There's a brake line on the top of the x member under the pan. How close are you to that?
Old Jun 25, 2024 | 10:59 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: hooker 2460HKR
Originally Posted by wruiz
Hi all,
do your aluminum heads have raised ports... often these are about 1/2" difference
Old Jun 29, 2024 | 04:41 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: hooker 2460HKR
As alan91Z28 said, some alum heads come with raised exhaust ports. AFR heads have .100" raised exhaust ports. There are other alum heads, like Blueprint, with 1/2" raised exhaust ports. Of course, check the oil pan first as other members suggested.
Fred
Old Jun 29, 2024 | 05:06 PM
Car: 82 TA
Re: hooker 2460HKR
I have raised port heads and have no y pipe clearance issues. I also have dons headers so that's not a direct comparison. I had Edelbrock TES header prior and still had no issues. If the headers have a ball/socket collector vs a flat/3 bolt flange maybe adding/modifying the slip fit part or the y pipe may gain some room. Sure would beat lifting the engine to swap the pan.
Old Jul 15, 2024 | 06:16 PM
sbrown's Avatar
Re: hooker 2460HKR
I was looking at these same headers for my 87 firebird 383 with aluminum heads. How do they fit? I have a 5 speed and the no name headers I have hit the slave cylinder. I'm juust looking for something that fits properly. Thank you in advance
Old Jul 18, 2024 | 06:32 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: hooker 2460HKR
They fit well, no issues with stock 350sbc. But with new crate and alum heads the y pipe hits the oil pan.
BlueZee28
Jun 23, 2007 10:49 AM
Phatfiddler
Jul 15, 2006 03:09 PM
Scorpner
Oct 3, 2005 10:57 AM
groundrat
Feb 16, 2004 09:54 PM
