Will a Bullet-Style Muffler be easy enough to install? (crappy diagram included)
Old Feb 6, 2025 | 10:00 AM
Smykster's Avatar
Car: 1991 RS 305TBI
91 RS 305 with completely stock exhaust. I want the Flowmaster Flow FX bullet style muffler
I drew a diagram of my thought process. Basically delete everything from the stock system from the axle back except the intermediate pipe. I would connect the muffler to the intermediate pipe then either have a turn down tip or straight tail pipe going to the back. It looks like I would lose the ability to use the hanger on the drivers side which is why I thought a small turn down pipe would be best. Let me know if this looks like it would work.
Old Feb 6, 2025 | 10:39 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Will a Bullet-Style Muffler be easy enough to install? (crappy diagram included)
As far as exhaust systems are concerned, you can make just about anything work if you have welding equipment and the skill to use it.
Old Feb 7, 2025 | 05:29 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
You didn't say why you want to do this and that's ok. That will be LOUD. I would run a tail pipe out the back just to get rid of fumes.
Old Feb 7, 2025 | 09:17 AM
Smykster's Avatar
Car: 1991 RS 305TBI
I do in fact want it louder(I actually can't hear the stock exhaust at all). I listened to some clips of this muffler and it sounds very similar to a magnaflow magnapack. The cars that still had stock manifold and cats sounded tame enough.
Good call about the fumes. Maybe I'll just have it go out back and deal with the fact that I'll only have 1 visible tip.
I'm not a big fan of the chambered exhaust sound and the other crossflow options didn't impress me either.
Old Feb 8, 2025 | 11:30 AM
With nothing holding it up on the driver's side end, it won't stay on the car for long.
Old Feb 8, 2025 | 03:32 PM
Smykster's Avatar
Car: 1991 RS 305TBI
this was my main concern.
Old Feb 13, 2025 | 11:00 AM
Abubaca's Avatar
Something else to mention. Me personally, do NOT like the sound of low compression engines right out of the pipe. NEEDS a muffler in my opinion. If you've heard it on a similar motor then you'll already know, but if you've heard it on a DIFFERENT motor......ya might not be happy.
Old Feb 13, 2025 | 11:57 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Run the pipe out the back and mount it to the factory mounts. Will probably sounds like *** but it is doable
Old Feb 17, 2025 | 11:35 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I did this way back in the day. I made a hanger for the drivers side.
Old Feb 17, 2025 | 06:16 PM
Smykster's Avatar
Car: 1991 RS 305TBI
https://www.youtube.com/watch?v=9XYO6wlA_LI
looks great! What muffler was it?
Old Feb 18, 2025 | 12:15 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks!
https://www.classicchambered.com/classic/products.html
Old Feb 18, 2025 | 03:22 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
In some states, at least, it's a safety requirement to have the exhaust protrude 1" outside the vehicle compartment....for the purposes or ensuring fumes don't make it into the cabin area. So, fumes is a concern as well as legal requirements too. As for one tip, I think F-bodies look "proper" with two tail pipes in the back, you could always do a Y pipe after the muff, or just have a dummy tail pipe on the right side, like this poser BMW....
It looks like I would lose the ability to use the hanger....
^That. Make a hanger. Easy Button.
wilesbd
Nov 13, 2011 09:58 AM
shahi
Jul 18, 2008 09:10 AM
f1ls1
Southern California Area
Apr 10, 2006 11:00 AM
camaroboy92RS
Dec 13, 2002 10:33 AM
