Black widow or any straight through muffler
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
With our single pipe system. Mines a 3" all the way back. How are you all fitting those mufflers, like the Neighbor hater for example? I assume the the muffler would be inline with the Cat. Since there won't be any muffler under the gas tank, how are you dealing with the two tail pipes? Do the muffler shops have Y connections to deal with that? Any pics would be great.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Black widow or any straight through muffler
Spintech makes a muffler delete pipe. It's essentially a y pipe in reverse. It's gonna be loud as hell. W a muffler far up stream I'd worry about drone but at the point of a straight through muffler, I'm assuming noise is lower on your list of concerns. I almost did a spintech delete or something like it and 2 straight through mufflers in the tail pipes. I chose against it, my car is loud enough.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
