Spohn X member and hedman LT
Old Oct 6, 2025 | 05:45 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Transmission: 700R…for now
Axle/Gears: 4.10
Hopefully this helps someone, I did this over the weekend Spohn X member with Hedman LT 3” pipe into Y. Also has the Blueprint heads with the raised exhaust ports .500.
i mau do some revision on the passenger side and make more of a soft bend.
I couldnt find any examples of this anywhere so I figured I would go head first and build it.
Not the best but also not the worst i seen, just have to weld it out now….first time for this bte
Old Oct 6, 2025 | 08:55 PM
skinny z's Avatar
Re: Spohn X member and hedman LT
This is mine. It's a sliced and diced series of cuts from a couple of stainless J-Y bends. The factory crossmember was radiused (and reinforced) for added ground clearance.
There's also a Magnaflow 2 x 2-1/2 into 3" merge. All of the attachments are flanged 3-bolt although if I were do this again, it would be v-banded. Probably skip the stainless too.
A little massaging on yours, such as the spot you've mentioned, wouldn't be a bad thing.
Old Oct 7, 2025 | 06:50 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
Yeah it would have been alot cleaner if i had the stock crossmember, the Spohn ones are super bulky. I will def go V band next time around, im building a L92 and have a TH350 so it won’t be a forever thing. I have a stainless Y just didn’t feel like buying wire and the exhuast is mild steel so I just built my own.
Old Oct 7, 2025 | 08:38 AM
skinny z's Avatar
Fair enough. You have to work with what you have.
I've noticed the bulkiness of the Spohn crossmember and it's a killer with respect to exhaust clearance as you noted. I do like the drive shaft loop that's available though.
I bought a Holley/Hooker crossmember as I was contemplating fitting a different transmission other than the 700.
I've still got this in the box.
The arches for exhaust clearance provide for plenty of room.
I may do something with it still.
Be sure to follow up with your results.
And the L92 and TH350 swap.
Old Oct 16, 2025 | 06:05 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
i may do some revision on the passenger side and make more of a soft bend.
Not the best but also not the worst i seen, just have to weld it out now….first time for this btw
Done
File Type: mov
Old Oct 16, 2025 | 07:59 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I have a spohn x member. My car is lowered 1.5in(ish). The x member has hit the ground many times. The driveshaft loop mount I cut and re-angled. I modified the x member to have more ground clearance also. If I had pipes that low, they'd be dragging or get ripped off. Is your car a stock hight?
Old Oct 16, 2025 | 10:48 PM
skinny z's Avatar
Done
Sounds GREAT!
What's the engine combination?
Old Nov 18, 2025 | 09:10 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
Yes it is stock height and the exhaust just BARELY sits off the ground
Old Nov 18, 2025 | 09:14 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
Sounds GREAT!
350
holley 650
edelbrock air gap
blue print 195 heads (2.02/1.60)
howards 270/278-.495/.500 @ .215/.225–110lsa
full roller rocker arms
howards LS lifters
Flat top 4 valve relief pistons
Wpeltz
Dec 10, 2025 08:34 PM
awilson82
Apr 17, 2008 08:25 AM
black355formula
Oct 29, 2007 09:44 PM
